IM stud hole stripped?
Old Aug 2, 2003 | 07:45 PM
FastNFurious
Guest
Posts: n/a
Default IM stud hole stripped?
My intake manifold gasket blew and I'm having idle surges.
I figured it out to be that one of the studs holding the manifold isn't even screwed in. I pulled it out and theres metal around the threads and it won't screw back in.
Anyone know of a way to fix this? Can I just retap the hole oversize and use a bolt?? or do I still have to use a stud and nut?
Thanks
Old Aug 2, 2003 | 08:18 PM
FastNFurious
Guest
Posts: n/a
Default Re: IM stud hole stripped? (David555)
heeeeeeeeeeelllllllllppppppppppp.................
Old Aug 2, 2003 | 09:03 PM
CircuitFG's Avatar
think you can retap it. ..
Old Aug 2, 2003 | 09:36 PM
user 996328629's Avatar
Default Re: IM stud hole stripped? (CircuitDA9)
those studs SUCK, there a pain in the ***. what i did was use a actual sqrew in..No stud.. If u need a bigger one cuz u stripped it, than so be it. But try a exact thread as OEM. see if its just a little u stripped, maybe its still salvagable. Hope this helps!
Old Aug 2, 2003 | 09:46 PM
Kamin's Avatar
Default Re: IM stud hole stripped? (Swags04)
hope its the stud that is stripped off, not the head, but yes if you have to you can tap it larger and drill out the IM to match. also may have to enlarge the gasket.
Old Aug 3, 2003 | 12:00 AM
LSVTEC1.8T's Avatar
used a thing called a healacoil that will work
Old Aug 3, 2003 | 12:07 AM
Kamin's Avatar
Default Re: (LSVTEC1.8T)
Helicoil.
Old Aug 3, 2003 | 06:42 PM
LSVTEC1.8T's Avatar
Default Re: (Kamin)
THANKS
Old Aug 3, 2003 | 06:43 PM
Kamin's Avatar
NP just trying not to confuse the poor kid.
D.j. Holley
10
Oct 3, 2024 01:30 AM
SIRIUS VTEC
19
Aug 22, 2010 03:38 PM
minime-civic
Jun 29, 2008 03:22 PM
hatchattak
Aug 11, 2004 09:48 AM
TurbothisLS
Dec 19, 2002 03:40 PM
