my e brake doesn't hold
Old Aug 2, 2003 | 04:21 PM
Do_Ster's Avatar
Default my e brake doesn't hold
hey guys, gotta problem. my e brake doesn't hold so when i park i always have to leave it in gear. but it sucks cause if the incline is too big, my car still rolls back when it's in gear. is there a way to fix this? i have an eg with drums on the back. i already tightened the cable by the handle already and still nothing. my shoes on the back are good. any suggestions?
Old Aug 2, 2003 | 07:32 PM
crxhybrid1320's Avatar
Default Re: my e brake doesn't hold (ntogethernow)
Adjust the star wheel inside the drums. But not too tight you will warp the drums. Just click the star wheel five clicks and put the drum back on, spin the drum and continue this until the drum starts to scuff the shoes.
Old Aug 2, 2003 | 09:29 PM
Do_Ster's Avatar
thanks man i'm gonna try it tommorow. does the star wheel look like it's name?
Old Aug 2, 2003 | 09:35 PM
Mr. Choi's Avatar
New User
Default Re: (ntogethernow)
open up the drums and you'll see it. looks like the name yes.
Old Aug 3, 2003 | 06:10 AM
LoNslo's Avatar
Default Re: (Mr. Choi)
running to my car right now and getting this accomplished...
Old Aug 3, 2003 | 11:53 AM
Do_Ster's Avatar
lonslo, i didn't get to try the star wheel method yet, no time, but i wanted to know does it work?
Old Aug 3, 2003 | 01:07 PM
Do_Ster's Avatar
hey guys the star wheel method works good but i screwed up on the left side now i can't put the drum back on, what do i do?
Old Aug 3, 2003 | 01:26 PM
You put it too tight the shoes are out too far. Use two screw drivers one to lift up the stopper and the other to reverse the star wheel in the opposite direction. loosen up alot and push the shoes together. then tap the drum on and spin. If its loose still tighten alittle at a time.
Jason
Old Aug 3, 2003 | 01:36 PM
95hatch's Avatar
If im not mistaken there should be an access hole for the star wheel on the inside of the brake assembly, so you dont have to take off and on your drum.
Old Aug 3, 2003 | 01:43 PM
Default Re: (95hatch)
ya but if you do it too tight fom the access hole its hard to loosen and get the drum off. If you are doing this for the first time better to do with the drum off. Make sure to clean out all the brake dust.
Old Aug 3, 2003 | 02:38 PM
Do_Ster's Avatar
thanks for all the help guys, i won't be able to do it tonight but i'll do it first thing tommorrow morning. so please check back in this topic in case i get stuck again. thanks everyone for the help
Old Aug 4, 2003 | 02:54 PM
Do_Ster's Avatar
thanks for all the help crxhybrid1320, e brake works great
Old Aug 4, 2003 | 03:39 PM
I guess it helps when you work at a dealership and do this 5 times a day everyday
Welcome
Old Aug 8, 2003 | 07:47 AM
T4eg's Avatar
Default Re: (crxhybrid1320)
try to get your drums turned and new brake shoes. make sure to adjust everything right. and you should be ok.
Old Aug 8, 2003 | 12:00 PM
nevin's Avatar
you want the drum to fit as snug as pussible but still spin when you put it on. I did this and my ebrake is super strong for fat *** draging drifts in the rain
Malt-liquor
Jun 25, 2019 08:51 PM
thatcivic96
Suspension & Brakes
Mar 6, 2014 06:20 AM
moaterboaink1ng
Suspension & Brakes
Oct 29, 2012 11:42 AM
kelley_james
Nov 30, 2009 01:22 PM
fbjunkie53
Sep 10, 2007 02:04 PM
