ALMOST lost it on the freeway earlier!!!!
Old Aug 1, 2003 | 10:27 PM
kHoA DoGG's Avatar
Default ALMOST lost it on the freeway earlier!!!!
I just drove my friends EG coupe to run an errand and it was the scariest thing in the world. It's lowered on Eibach sportline w/ 195/50/15 tires. It's got stock shocks but at 60-70mph and hitting uneven pavement the back end will want to swing out. What's going on???
Are the springs not installed correct? Are the shocks not rebounding? Is this the famous...bumpsteer? Any help or suggestion would be appreciated.
Old Aug 2, 2003 | 12:38 AM
kHoA DoGG's Avatar
Default Re: ALMOST lost it on the freeway earlier!!!! (sNoOziN' EF8)
ttt
Old Aug 2, 2003 | 09:01 AM
kHoA DoGG's Avatar
anyone?
Old Aug 2, 2003 | 09:58 AM
tilt's Avatar
First off, check tire pressure. Easiest way to lose traction cornering is underinflated tires. 2nd, are the tires the same, different tires are going to have a different grip threshold. 3rd, are the tires crappy tires? Upgraded suspension should be paired with decent sticky tires.
Stock shocks should be ok if they are working.
Old Aug 2, 2003 | 12:02 PM
Lsos's Avatar
If the Eibach springs are stiffer than stock, they need stiffer shocks to control them...otherwise it's no good.
Old Aug 2, 2003 | 12:23 PM
acuracing's Avatar
Is his alignment correct?
Old Aug 2, 2003 | 05:07 PM
D-Man's Avatar
Default Re: ALMOST lost it on the freeway earlier!!!! (acuracing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acuracing &raquo;</TD></TR><TR><TD CLASS="quote">Is his alignment correct? </TD></TR></TABLE>
that's what im thinking,his alignment is probably out....did he have a 4 wheel alignment done after he lowered it?
Old Aug 3, 2003 | 09:49 AM
kHoA DoGG's Avatar
Default Re: ALMOST lost it on the freeway earlier!!!! (D-Man)
alignment it is.. and it's a girls car...
Old Aug 3, 2003 | 10:24 AM
Aron Parsons's Avatar
Bad alignment, improperly inflated tires, bad shocks, incorrect installation of springs, etc etc. It could be a lot of things, and likely a combination of them. Alignment and tire pressures would be at the top of the list for what you experienced.
Old Aug 3, 2003 | 12:46 PM
Weston's Avatar
It's bad toe. With incorrect toe after lowering, the tires are fighting each other, but canceling each other out so you still go straight. When one tire loses traction, it can no longer cancel out the other tire, and it'll pull the car in the direction that it's pointed.
Old Aug 3, 2003 | 01:10 PM
Ya@inlinePRO's Avatar
Default Re: (Weston)
wow, thats scary, and you were goin straight on the freeway? only thing i can think of are those mentioned. get it check out.
Old Aug 3, 2003 | 02:20 PM
kHoA DoGG's Avatar
Default Re: (kwik2nec)
will an alignment job take care of the toe also? Or is that something that has to be requested?
Old Aug 3, 2003 | 02:35 PM
Russ713's Avatar
dAng!
Default Re: (sNoOziN' EF8)
it's part of the alignment.
Old Aug 3, 2003 | 02:50 PM
kHoA DoGG's Avatar
Default Re: (Russ713)
thanks, i'm going to go get an alignment and see where it goes from there.
Old Aug 3, 2003 | 05:55 PM
Weston's Avatar
Yes, when you get an alignment, toe is the main thing that they adjust. Toe is the only thing that can be adjusted without having to install additional hardware like a camber/caster kit.
Old Aug 3, 2003 | 06:02 PM
mmuller's Avatar
Mad Scientist
Mine does the same on the rear, when i go through a bump or uneven pavement the back jumps to the left.I'm pretty sure is the trailing arm bushings that are broken.
Old Aug 3, 2003 | 07:06 PM
GSpeedR's Avatar
Default Re: (mmuller)
This isn't a personal crack or anything kinda **** like that, but poor driving will bring out the worst in even a well-setup car. You're implying that you were driving fast (tail won't step at 35mph...if so, then the car has issues). Is this on an on-off-ramp?
Bumpsteer usually only applies to the front, so unless it's so bad that you're giving really significant steering input. The shocks are properly gone, but I agree that a needed alignment is the culprit.
Modified by GSpeedR at 11:16 PM 8/3/2003
Old Aug 3, 2003 | 07:25 PM
Mohudsolo's Avatar
Default Re: (GSpeedR)
A lot of lowering springs are not stiff enough to keep the car off the bumpstops. What if the back is hitting the stops? That would make the car go from steady state to woohoo really quickly. Add in stock shocks that may have been beaten up badly from bottoming, and the toe out that comes from no alignment after lowering and the car could be a handfull going through the drivethrough, much less at any speed.
Old Aug 3, 2003 | 08:55 PM
kHoA DoGG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GSpeedR &raquo;</TD></TR><TR><TD CLASS="quote">This isn't a personal crack or anything kinda **** like that, but poor driving will bring out the worst in even a well-setup car. You're implying that you were driving fast (tail won't step at 35mph...if so, then the car has issues). Is this on an on-off-ramp?
Modified by GSpeedR at 11:16 PM 8/3/2003</TD></TR></TABLE>
actually, that speed was on the freeway.
JDMhatchback20
12
Oct 14, 2007 09:38 AM
ezekel
Suspension & Brakes
Sep 21, 2006 10:47 AM
GoLowDrew
Sep 24, 2004 09:36 AM
yusoslo
26
Oct 10, 2002 05:14 PM
Flux
May 19, 2002 03:15 PM
