distributor differnces?
Old Aug 1, 2003 | 08:35 PM
wm5holla's Avatar
Default distributor differnces?
do obd0 ,obd1 and odb2 look the same, i mean how do uknow if ur buying the rite distributor? i dont need to get scammed!!
Old Aug 1, 2003 | 09:32 PM
Kataku2K3's Avatar
Default Re: distributor differnces? (wm5holla)
You can basically just go by the connectors... OBD1 and OBD2 are internally the same (they have the same trigger) where as nonOBD fires at a different pulse rate making it incompatible with OBD1/2... nonOBD connectors are straight ugly, both connectors will be round making it easily identifiable... OBD1 have TWO connectors which both should both be gray... Most OBD2 distributors use a single connector which is my favorite due to just plain looks... The one thing to know is that all B series VTEC distributors (*just as an example) share the same casing meaning that their shells all look pretty much the same (also meaning that they'll bolt up to any B series VTEC head)... Just my $0.02, and always ask for pics if you are buying online... If you get any pics and you are still not sure just let me know and I should be able to tell ya unless plugs, pins, connectors, or internals have been swapped... Peace
Old Aug 1, 2003 | 09:38 PM
wm5holla's Avatar
Default Re: distributor differnces? (Kataku2K3)
I NEED A 94-95 a dist FOR my b18a. can i use a vtec one(94/95 gsr)? or will itbetter to use a 94-95 LS dist
Old Aug 1, 2003 | 09:58 PM
porsche997dc2's Avatar
you will be better to use the 94-95 ls one. You can use the vtec one but it probably hold with only one bolt.
Old Aug 1, 2003 | 10:16 PM
wm5holla's Avatar
Default Re: distributor differnces? (porsche997)
a vtecdist will bolt to a non vtechead ?
Old Aug 1, 2003 | 10:17 PM
yes but only hold up with one bolt
Old Aug 2, 2003 | 08:39 PM
wm5holla's Avatar
so it would better to use a non vtec one, two bolts must be better than one bolt!
Old Aug 3, 2003 | 06:17 AM
4inspeed's Avatar
there are 3 bolts on a dizzy, some people use different dizzy's from different cars that are more readily available then there specific cars and leave out a bolt, if you HAVE to do this AT LEATS MAKE SURE YOU CAN USE 2 of the 3. only a MUST, i personally wouldnt but maybe if that was the only option i had to get to work in the morning i would cosider it.
Old Aug 3, 2003 | 08:18 AM
Kataku2K3's Avatar
Default Re: distributor differnces? (4inspeed)
I would just go with the nonVTEC one but that's just me... When it comes to the motor I can't stand leaving bolts out... You could use a 96-2001 LS dizzy too and just repin the connector on the engine loom (looks cleaner) or cut the plug off and put an OBD1 one on... That opens up a few more options as well... Good Luck
Old Aug 3, 2003 | 10:08 AM
wm5holla's Avatar
how i can i use a 96 dizzy. i want to do no extra wiring.. i think it would best if i got a 94/95 LS dizyy. but what i asked was how can i tell the diffence bewttwen a 00 b16a2 dizzy and 93 gsr dizzy or a d16 dizzy
ogmudbone
Mid-Atlantic (Sales)
Sep 20, 2009 08:06 PM
DasaEJ1
Sep 21, 2005 06:46 PM
SIsohcvtec
Sep 6, 2004 04:44 AM
highvelocitynyc
Aug 17, 2003 10:17 PM
misledyouth
Sep 5, 2002 05:49 AM
