will a 3" dp fit in here
if it will, what degree of bends do i need? its a garrett t3/to4e on right now but my sc61 is going to go in later, so i not sure will it have enough room or not.
You'll need a slim fan but it should...I made a 3" for a similar setup not too long ago. The first bend will have to be cheated slightly like the smaller d/p in the pic but once you get the fan outta the way it should be alright.
--Ian
--Ian
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by clendaniel »</TD></TR><TR><TD CLASS="quote">You'll need a slim fan but it should...I made a 3" for a similar setup not too long ago. The first bend will have to be cheated slightly like the smaller d/p in the pic but once you get the fan outta the way it should be alright.
--Ian
</TD></TR></TABLE>where can i get a slim fan at?
--Ian
It will fit for sure if you run a pusher fan.That thick fluidyne isnt helping on clearance issues either. The bad thing is it will create alot of heat depending on how rich or lean your motor is running. It would be wise to wrap the DP with thermal wrap. You would be better off turning the turbo the other way and as long as you dont have AC you will be clear and free from anything in the way and the 3 inch DP would be perfect.
platinum00
Jul 30, 2006 07:55 AM
6MTV6
Jun 8, 2004 11:04 AM
