How would you replace a TDC censor?
Old Aug 1, 2003 | 01:14 AM
hybridEj6's Avatar
Default How would you replace a TDC censor?
where is the TDC sensor inside the distributor? Also where exactly do i put the jumper wire on the harness to check stored engine codes?
Old Aug 1, 2003 | 04:13 AM
EE_Chris's Avatar
Default Re: How would you replace a TDC censor? (ekhybrd)
If the TDC sensor is bad, replacing the sensor means replacing the entire distirbutor sub-assembly.
If you look up under the dash where the ECU is, there should be a green rubber plug which contains a blue 2-pin connector. Its this connector that you can use a paper clip to short out to check for engine codes.
Old Aug 2, 2003 | 02:05 AM
hybridEj6's Avatar
Default Re: How would you replace a TDC censor? (EE_Chris)
What does the sub assemby consist of?
Old Aug 2, 2003 | 10:42 AM
HONDADNA's Avatar
The distributor
Old Aug 2, 2003 | 01:24 PM
hybridEj6's Avatar
Default Re: How would you replace a TDC censor? (HONDADNA)
Thats not good
naderesb
Nov 20, 2022 02:36 AM
Unphzd
Dec 13, 2010 11:30 PM
i_VTEC
17
Oct 15, 2007 10:17 AM
BRAWDY03
May 13, 2004 04:50 PM
0utaSight
11
Oct 29, 2003 07:49 PM
