Temp gauge doesnt work after swap
Old Jul 31, 2003 | 07:42 PM
SC0TT's Avatar
Default Temp gauge doesnt work after swap
Just finished a b16a swap on a crx. The temperature gauge isnt working anymore. What should i check or go over..thanks for the help.
Old Jul 31, 2003 | 07:50 PM
Blaze45's Avatar
Brrraaaap!
Default Re: Temp gauge doesnt work after swap (SC0TT)
The stock water temp sensor is located under the dizzy, you should have a single wire just laying in that general area under your dizzy. Youll know that its the water temp plug cause its a 1 prong female plug that goes right onto the sensor.
hth
Blaze
Old Jul 31, 2003 | 08:34 PM
poison's Avatar
Default Re: Temp gauge doesnt work after swap (Blaze45)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blaze45 &raquo;</TD></TR><TR><TD CLASS="quote">The stock water temp sensor is located under the dizzy, you should have a single wire just laying in that general area under your dizzy. Youll know that its the water temp plug cause its a 1 prong female plug that goes right onto the sensor.
hth
Blaze</TD></TR></TABLE>
Yup, this is the coolant sending unit located next to the ECT. Make sure it's not broken, and that it's plugged in.
BlackShingo
May 20, 2010 07:36 AM
whitecrx
Aug 3, 2005 09:53 AM
TypeR15
Feb 24, 2004 12:29 PM
ten_30
Oct 2, 2002 11:08 AM
2000_Civic_Si
Apr 3, 2002 07:45 AM
