Dented oil pan. Any consequences?
Old Aug 7, 2001 | 09:23 AM
Kalokohan's Avatar
New User
Default Dented oil pan. Any consequences?
Hey guys, I changed my oil for the first time since the swap and noticed that my oil pan was dented. This probably happened during shipping. I was wondering what the consequences may be. Should I replace the oil pan?
Old Aug 7, 2001 | 09:38 AM
Kalokohan's Avatar
New User
Default Re: Dented oil pan. Any consequences? (Teken)
It's dented in about an inch deep in some parts and about 1/2 an inch on other areas. I guess it's because they had it on a pallet while shipping it. I changed my oil the other day and I put 3 1/2 quarts in, yet it's already almost on the second hole on the dipstick. Could the oil pan be the culprit?
[Modified by Unleashed5GHBGS-R, 6:41 PM 8/7/2001]
Old Aug 7, 2001 | 09:41 AM
Chris's Avatar
Default Re: Dented oil pan. Any consequences? (Unleashed5GHBGS-R)
small dent...dont worry. Not leaking is it...your fine. Why use JB Weld???
Old Aug 7, 2001 | 09:42 AM
Kalokohan's Avatar
New User
Default Re: Dented oil pan. Any consequences? (Chris)
No leaking so far. Thanx for the re-assurance. I've been in a car where all the oil leaked out and the engine seized while doing like 70mph.
Old Aug 7, 2001 | 10:08 AM
berkel's Avatar
Hmmmmm,
One issue is that if it's dented, it may interfere with the oil getting picked up properly? Isn't 2 inches kind of a big dent? It may be weaker and more likely to fail I'm not sure though...
Maybe it's a good time to get a Moroso?
FB
Old Aug 7, 2001 | 11:28 AM
keithv's Avatar
I would change the oil pan ASAP. The oil pickup sits very low to the bottom of the oil pan (on my ZC at least) and with a dented pan, you can have oil failure.
I would think the oil pan is the culprit to your oil level woes.
You don't want bearings looking like this: http://kjvieira.tripod.com/pics/car/...arings-BAD.jpg
Old Aug 7, 2001 | 12:27 PM
Kalokohan's Avatar
New User
No, it's not the grooves, it deeper than that. How hard is it to change an oil pan?
Old Aug 7, 2001 | 12:44 PM
Chairman Kaga's Avatar
Similar question...
I noticed a bolt missing from my pan the other day. No leaking, thank god. I want to replace it. What size bolt and how tight?
Thanx...
Old Aug 7, 2001 | 12:54 PM
keithv's Avatar
Not that hard at all...
Drain the oil from the pan, remove your header/cat, remove the 20+ bolts holding the pan, and that should be it. I don't think I missed anything.
The hardest part will be with the header/cat bolts. They maybe rusted badly. If so, try to grind them off and get new ones.
bjones6215
Sep 10, 2013 07:55 PM
ballisticej1
13
Jun 14, 2009 08:50 AM
flipstar760
12
Dec 17, 2006 05:07 PM
hondaboy4life
Sep 29, 2006 08:01 AM
rival12
Sep 20, 2005 04:29 PM
