installed new shift linkage and SS, play while in gear?
Old Jul 31, 2003 | 06:41 PM
type Gendy's Avatar
Default installed new shift linkage and SS, play while in gear?
I just installed a new hasport shift linkage on my crx tonight.... and a skunk2 SS. I noticed when the car is in gear, it has side to side play, almost like it is in neutral. Has anybody else experienced this before, have i done something wrong?
Old Aug 1, 2003 | 03:44 PM
type Gendy's Avatar
up^
Old Aug 1, 2003 | 04:20 PM
HondaEF_Hatch's Avatar
Default Re: (sick hatchem)
in my car , 88 dx hatch, when i bought the car it had a short shifter, i dont know if it was ghetto done or not, im pretty sure its just chopped and welded, but i have hella play while in gear......diff from shift linkage but i know the feeling ur talking about
Old Aug 1, 2003 | 04:40 PM
Slow*Jim's Avatar
Default Re: installed new shift linkage and SS, play while in gear? (sick hatchem)
i bought my car 3 years ago and the shifter did the exact same thing... then i looked in my Chilton's manual and figured out what it was... theres this little u-shaped dealie under the shift linkage that keeps the shifter from moving side-to-side (it would be located about 4" BEHIND your shifter on the little extended part of the linkage if your rex had it)
Old Aug 1, 2003 | 08:20 PM
type Gendy's Avatar
Default Re: installed new shift linkage and SS, play while in gear? (SlowJim)
Are you talking about that rubber "boot" that bolts the linkage up in the rear?
Old Aug 1, 2003 | 10:56 PM
raene's Avatar
Yes, I think he is.
Old Aug 2, 2003 | 05:11 AM
type Gendy's Avatar
I dont see how you can phukk that up? IF you dont bolt it up tight, your **** is gonna be real sloppy....
Old Aug 8, 2003 | 09:51 PM
VashTheStampede's Avatar
No tears. Only dreams, now.
I know that this is an old topic, but I also just installed a new HAsport linkage, and I've got the same weird-*** side to side play while in gear, you CAN'T find a single damn gear, cuz you can't tell what gear it's in to start with..... My guess is that it's the pin.. any ideas?? Could the pin be the prob?
Old Aug 9, 2003 | 05:50 AM
type Gendy's Avatar
ARe you refering to the bitch pin that bolts it up near the tranny? I dont think that is the source of the play.... Are you using a short throw shifter as well?
I know, it is very difficult knowing what gear you are in, i dont think i would let anybody ever drive my car with this setup........but now i have an excuse
Old Aug 11, 2003 | 10:07 AM
Actually, I've got the stock shifter, but I'm about to put in a B&M short throw. I thought that it might be the pin because I had to machine one myself from a bolt, and I figure that it's too small to grab both holes. I'm gonna call honda and order a new pin... maybe that'll fix it, I'm also gonna put on the short shifter, and some new bushings. haha.. and if that doesn't work, I'm thinking about making a slotted metal plate for the shifter to slide in and out of.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sick hatchem &raquo;</TD></TR><TR><TD CLASS="quote">ARe you refering to the bitch pin that bolts it up near the tranny? I dont think that is the source of the play.... Are you using a short throw shifter as well?
I know, it is very difficult knowing what gear you are in, i dont think i would let anybody ever drive my car with this setup........but now i have an excuse </TD></TR></TABLE>
lol...Amen to that... screw anti-theft, you can't steal what you can't get into gear.
Old Aug 11, 2003 | 10:37 AM
To Muckin Fuch's Avatar
Default Re: (VashTheStampede)
You need to install the washers to eliminate the side to side movement...Your SS needs to be snug and tight against the shift linkage...
Fardoche's Avatar
Weird, I just put the Hasport linkage and have the same problem - horrible feel, rubberish. Stock was much better...
Wondering where this play is coming from? It has to come from the transmission itself since that is where the "gates" are. It is almost impossible it would be the back of the shift linkage. More ideas anybody?
Old Aug 11, 2003 | 10:46 AM
HT Chaplain's Avatar
Loved
Default Re: (Fardoche)
i have the same problem with my hasport linkage and my stock shifter
Old Aug 11, 2003 | 11:31 AM
I lubed up the joints on the end of my linkage before I installed it... maybe it's too loose?? grrrr... I wanna find out. I'm about to install all that stuff, I'll let you know if I fix it.
Old Aug 11, 2003 | 11:49 AM
slooogsr's Avatar
mine does the same with stock linkage and a neuspeed SS............ it goes into gear fine and i dont miss a gear so im happy with it
Old Aug 11, 2003 | 11:54 AM
RexB16's Avatar
Default Re: (sloorex)
for most of you its that roll pin the holds the shift linkage to the shift rod. if thats not snug in here you will have play.
Old Aug 11, 2003 | 12:42 PM
ComposiMo's Avatar
This may help... its a bit pricey, but we've had no complaints yet
https://honda-tech.com/zerothread?id=563939
Old Aug 11, 2003 | 12:53 PM
type Gendy's Avatar
Default Re: (CRX-PRO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX-PRO &raquo;</TD></TR><TR><TD CLASS="quote">You need to install the washers to eliminate the side to side movement...Your SS needs to be snug and tight against the shift linkage...</TD></TR></TABLE>
I am pretty sure that i put the washers in, i guess i have to double check. That is about the only thing that ic an think of to cause the play.... My pin went in fine and is still in good shape.
Old Aug 11, 2003 | 03:38 PM
slooogsr's Avatar
you cant have the SS too tight on the linkage or shifting will be harder than a *****..........
Old Aug 11, 2003 | 03:41 PM
type Gendy's Avatar
Also true, i learned that the first time!
Old Aug 17, 2003 | 10:23 PM
FourthGenHatch's Avatar
Default Re:
When I tighten mine I do it until its real tight than back it off a couple turns. Always works great.
Old Aug 18, 2003 | 03:17 PM
type Gendy's Avatar
thats what i did, tightened it up, then backed it off a hair so i could shift easy, but i still get the play
Old Aug 18, 2003 | 03:42 PM
RCautoworks's Avatar
Talk to the guys at rpiracing.com , I know they had something in the works to fix this exact problem.
Jay_Mills
Jan 4, 2013 01:30 PM
BiGcAmBoDiAnSaUsAgE
Mar 23, 2007 10:56 PM
91SiRX
Jun 10, 2005 07:41 PM
SeaBass
Jul 9, 2003 10:25 PM
