Has anyone converted 98 harness to 95 harness ecu plugs only
Old Jul 31, 2003 | 06:03 PM
K20  EG's Avatar
Default Has anyone converted 98 harness to 95 harness ecu plugs only
anyone ....i did one today and when i start the car it misses constantly
i know there is another kinda crank trigger on the crank i dont know what purpose it serves ...
has anyone done this ...am i missing somethin ...i had two wire diagrams side by side ...i thought i had it done right
i know i got the tdc cyp and cpk ...wires done correctly ...
Uggh
thanks in advance
Old Jul 31, 2003 | 08:37 PM
poison's Avatar
Default Re: Has anyone converted 98 harness to 95 harness ecu plugs only (K20 EG)
What ECU are you using, what motor, and what harness?
Old Jul 31, 2003 | 09:17 PM
K20  EG's Avatar
Default Re: Has anyone converted 98 harness to 95 harness ecu plugs only (poison)
the car is a 97 integra Ls
motor is a B-20 Vtec
the harness is a 95 gsr
Old Jul 31, 2003 | 09:41 PM
deepstaged's Avatar
On the OBD2 motors, the crank angle sensor is located on the block itself. That is the sensor you see.
On the OBD1 motors, the crank angle sensor is located inside the distributor.
Just rewire accordingly and it should fix the problem.
Old Jul 31, 2003 | 11:48 PM
K20  EG's Avatar
Default Re: Has anyone converted 98 harness to 95 harness ecu plugs only (deepstaged)
should i be going in the direction of the way the harness is in the engine compartment or the ecu location
Old Aug 1, 2003 | 04:25 AM
EE_Chris's Avatar
OBD2 engines integrated a Crankshaft Fluctuation sensor for misfire detection, which is located by the oil pump.
They [OBD2] distributors have always had a Crank Position sensor, as well as the TDC and CYL sensors.
Old Aug 3, 2003 | 11:50 AM
Fabrik8's Avatar
Default Re: Has anyone converted 98 harness to 95 harness ecu plugs only (EE_Chris)
Did you change the ECU plugs yourself or use an adapter harness?
Old Aug 4, 2003 | 03:39 AM
K20  EG's Avatar
Default Re: Has anyone converted 98 harness to 95 harness ecu plugs only (Fabrik8)
i changed the Ecu plugs myself
pain in the *** ...
Hot weather outside
Hot soldering iron
bad mix
Slammerdc2
Oct 22, 2016 05:16 AM
SlowSOHC-T
Dec 13, 2007 11:46 AM
