Need a new ecu what would you do?
Old Jul 31, 2003 | 12:56 PM
ramz7887's Avatar
Default Need a new ecu what would you do?
My ecu is faulty so i need to put a new one in what should i do? Do i buy a chipped one or regular one? I have a 98 ex. I have an i/h/e and i play on running a zex system soon and later some better cams.
Old Aug 1, 2003 | 10:35 AM
ramz7887's Avatar
Default Re: Need a new ecu what would you do? (ramz7887)
ttt
Old Aug 1, 2003 | 11:10 AM
EE_Chris's Avatar
You had posted up a thread about Code P0133, which is related to the O2 sensor.
How do you know your ECU is duffed?
Old Aug 3, 2003 | 11:52 AM
Fabrik8's Avatar
Default Re: Need a new ecu what would you do? (EE_Chris)
Are you using your 98 ECU? Chipping those is kind of costly, and really isn't done a hell of a lot, and you can get OBD2 ECUs pretty easily because of the number of people doing OBD2 to OBD1 swaps. I would just get a replacement for what you have now, unless you are planning on doing ECU tuning in the future..
Old Aug 3, 2003 | 01:21 PM
mmuller's Avatar
Mad Scientist
Default Re: Need a new ecu what would you do? (Fabrik8)
obd2 to obd1 and chipped p28 or hondata
Old Aug 3, 2003 | 05:08 PM
Fabrik8's Avatar
Default Re: Need a new ecu what would you do? (mmuller)
I can get you an adapter harness if you need, I make them..
Old Aug 4, 2003 | 01:48 PM
ramz7887's Avatar
should i get a new ecu and then go with a vafc or hondata?
Old Aug 4, 2003 | 06:23 PM
Smith Wise's Avatar
replace with the same ecu
Old Aug 4, 2003 | 07:15 PM
hondapwr's Avatar
Default Re: Need a new ecu what would you do? (Jswpstdoff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jswpstdoff &raquo;</TD></TR><TR><TD CLASS="quote">replace with the same ecu </TD></TR></TABLE>
I agree, don't waste your money, just get a replacement from a junkyard. DON'T buy a new one, they are way overpriced. Remember to get a 96-98 EX ECU and not the 99-00 because the plugs won't match. The 96-97 Del Sol Si P28 should work too.
Don't bother with a VAFC or piggy back fuel controller either, all you need is an adjustable fuel pressure regulator if anything at all..
Old Aug 5, 2003 | 06:39 AM
ramz7887's Avatar
Default Re: Need a new ecu what would you do? (hondapwr)
Ok i'll go with the stock 96-98 ex ecu. What number is that Pxx?
Old Aug 5, 2003 | 06:54 AM
EE_Chris's Avatar
Since you have a 98 Ex, decoding the Pxx # is as simple as looking at your current ECU.
Zfracing
Mar 20, 2017 01:41 PM
thenoxus1
Engine Management and Tuning
Oct 17, 2011 07:49 PM
Najdmitr307
10
Mar 10, 2009 03:18 PM
lickety_britches
Nov 15, 2007 03:59 AM
ringgold
Jul 18, 2001 11:48 AM
