What coolant W/ copper headgasket?
I was told that you can not use regular coolant with a copper head gasket because it will corrode it and that I need to run straight water. Is this true? It makes sense but is there some sort of additve to mix with regular coolant? Thanks for your help.
A long time ago I asked if my homemade elbow would be ok for coolant, seeing as how its made out of copper. Here is a pic.
Anyways i was told its ok to use copper in my cooling system, and no corrosion will occur. Here is the link if you are interested
https://honda-tech.com/zerothread?id=495726
Apparantly, copper ha sbeen used in old radiators so its all good
spcrxracer
Feb 27, 2005 11:16 AM
