Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
$&#%! My Jeep won't start!!!
Old Jul 31, 2003 | 06:45 AM
speedracer33's Avatar
Default $&#%! My Jeep won't start!!!
Okay, this whole "going to the racetrack" thing would be a lot easier if my friggin tow vehicle would start.
Waiting for the tow truck for the tow vehicle.... with an 8 hour tow to the track ahead of me.....
Matt
Old Jul 31, 2003 | 07:00 AM
.RJ's Avatar
.RJ
Default Re: $&#%! My Jeep won't start!!! (speedracer33)
battery terminals? mine get crusty and the car wont start. Use some coke to clean them off.
Old Jul 31, 2003 | 07:43 AM
Todd Reid's Avatar
Default Re: $&#%! My Jeep won't start!!! (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">battery terminals? mine get crusty and the car wont start. Use some coke to clean them off.</TD></TR></TABLE>
come on man, do it right if you are going to do it.
get a terminal cleaner from Pep Boys (cylinder thingy with an internal wire brush. mix up a little baking soda and water. tooth brush it on the terminals. wipe it off. use the terminal brush till its nice and shiny and clean. wipe everything down with a WD40 soaked rag. apply some anticorrosion terminal gel to the terminals. check all the wires and the terminal attachements for corrosion and wear. replace if needed (Pep Boys!). use new hardware and reattach everything. should be good to go (if that was your problem). don't forget to check the battery and recharge if needed; bad grounds/wires/corroded terminals will keep the battery from charging correctly....
todd
PS can you tell i was brought up on a farm with lots and lots of old tractors? this was a sequence i performed many times on lots of different equipment....
Old Jul 31, 2003 | 08:13 AM
.RJ's Avatar
.RJ
Default Re: $&#%! My Jeep won't start!!! (Todd Reid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd Reid &raquo;</TD></TR><TR><TD CLASS="quote">come on man, do it right if you are going to do it. </TD></TR></TABLE>
"right" isnt always an option when you just need to make it work
Old Jul 31, 2003 | 08:15 AM
kedwards's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd Reid &raquo;</TD></TR><TR><TD CLASS="quote">SNIP
PS can you tell i was brought up on a farm with lots and lots of old tractors? this was a sequence i performed many times on lots of different equipment....</TD></TR></TABLE>
I was also brought up a farm, but my dad used a pocket knife to scrape the battery terminals. I introduced him to "new technology", such as battery terminal brushs (and ratchet wrenches, for that matter).
I now have the tractor that he and I rebuilt the engine in when I was in 9th grade.
We had the benefit of being able to park our tractors on a hill, so the starters (and generators) didn't always need to work.
I still dislike not being able to push-start vehicles with an automatic...
Old Jul 31, 2003 | 08:28 AM
KC's Avatar
KC
My Jeep doesn't start sometimes until I wiggle the stick in 'P' (it's an automatic).
The sensor on it is a little messed up.
--kC
Old Oct 2, 2003 | 02:29 PM
papa_smurf's Avatar
Default Re: $&#%! My Jeep won't start!!! (KC)
the neutral safety switches on the 4.0L automatics are really finiky, take it off and clean it up if you have a good amount of miles on it.
Old Oct 2, 2003 | 03:13 PM
Default Re: $&#%! My Jeep won't start!!! (papa_smurf)
LMAO! I actually did get it started between now and then, but thanks for your concern!
Matt
kiklo16
Aug 3, 2007 06:46 AM
k_lude
Feb 6, 2007 12:01 PM
eg686
Aug 22, 2005 10:16 PM
The Poopsmith
Dec 25, 2004 09:05 AM
xkhalil333x
Oct 16, 2003 06:16 AM
