Car wont start sometimes
sometimes after a day or so of not starting my car, it wont turn on or takes a really long time to turn on.
the thing is is that when it does turn on it turns over easily, it just takes a long time of holding the key in the start position.
Any ideas?
Any ideas?
Re: Car wont start sometimes (The Poopsmith)
I had the same problem..I noticed it went away after I switched out my cap (for stereo) and cleaned the battery terminals, as well....also checked out my grounds
check out your alt. maybe its bad?
good luck
good luck
Re: Car wont start sometimes (PLAGUED_DB7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PLAGUED_DB7 »</TD></TR><TR><TD CLASS="quote">I had the same problem..I noticed it went away after I switched out my cap (for stereo) and cleaned the battery terminals, as well....also checked out my grounds
good luck </TD></TR></TABLE>
battery terminals are clean, the grounds are secure too. I'm not sure about the alternator, but i don't think that has anything to do with just cranking the car? or am i wrong
It just happend again, the motor dosen't turn over at all, any other ideas?
**n/m i think its my failing OE alarm
Modified by The Poopsmith at 1:49 PM 12/25/2004
FindingEmo
08-05-2004 06:46 AM
