NO pressure in radiator!!??
Old Jul 31, 2003 | 02:18 AM
iwouldHITit's Avatar
Default NO pressure in radiator!!??
ok i went for a drive for about 15-20mins and when i got back i squeezed the top radiator hose and it was not hard at all..so then i took off the radiator cap and nothing happen... isnt it soppose to have fluid flying out or something??is my termostat not opening?
by the way its a b18b motor
Old Jul 31, 2003 | 03:19 AM
hahahahhah's Avatar
Default Re: NO pressure in radiator!!?? (iwouldHITit)
you know, I'm not completely sure, but it could be your radiator cap, or there is a leak in the radiator somewhere.. are you leaking coolant? are your coolant levels at the acceptable level? if you can, pressure test your rad, that will point you in the right direction. If the radiator DOES have proper pressure seal, and your levels of coolant are at their proper levels, check the radiator cap. (This is just in my opinion )
-Andy
Old Jul 31, 2003 | 08:28 AM
Blaze45's Avatar
Brrraaaap!
Default Re: NO pressure in radiator!!?? (CR1X)
No pressure after taken a drive? You could have a blown HG. Any white smoke or milky oil or oil like coolant? Is your car eating coolant? Take your plugs out and check em to see if any of them have a green tint to em.
Blaze
Old Jul 31, 2003 | 09:40 AM
martini's Avatar
Default Re: NO pressure in radiator!!?? (Blaze45)
check your overflow bottle. It may just be a bad cap.
Was the radiator/hose hot? If they weren't..it's probably a stuck thermostat.
Old Jul 31, 2003 | 05:39 PM
Default Re: NO pressure in radiator!!?? (martini)
the hose was hot..dunno about plugs still have to check
Old Jul 31, 2003 | 05:44 PM
Shawn C's Avatar
In The Garage
dude, if everything is good in your engine, you can drive around for 5 hours, pull over, and pop the cap, even with it running, and nothing should come out. if your car runs good, don't worry about anything. if you had a blown head gasket, coolant would spray everywhere when you popped the cap, since compression would be in the water jacket.
don't worry about anything. but if your car runs like ****, then you might have a problem somewhere.
92blm92
31
Nov 7, 2017 03:48 PM
Soooogie
Sep 29, 2013 04:54 AM
LuckyJDM
May 16, 2013 01:39 PM
Weston
29
Feb 5, 2005 06:59 PM
spoolinlude
May 7, 2003 06:49 PM
