battery location CRX
Old Jul 31, 2003 | 01:30 AM
djnikko's Avatar
Default battery location CRX
hi guys
has anyone experienced any difficulty with moving there battery to the boot of there rex? i.e. cold start problems etc
Also how vital is a MSD BTM ingnition setup for a boosted D16 honda? i will be running about 8 psi and how much should i aim to pay? 1st hand 2nd hand?
thanks
Old Jul 31, 2003 | 04:48 AM
keithv's Avatar
Default Re: battery location CRX (djnikko)
there are more in the archives, so search there, too.
https://honda-tech.com/zerothread?id=419606
https://honda-tech.com/zerothread?id=437775
Old Jul 31, 2003 | 06:56 AM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
It is essential that you have very good ground and a low resistance lead for your positive main. i used 4 guage for the lead to a power distributor located in the engine compartment which then splits to 8 guage to the main breaker and starter.
since the relocation, even though my battery is low on the fluid which leads to the alternator whine for a bit after the start, the lights, spark and starting is more consistent. i will have to replace the sick battery with something sealed and install a volt meter to really measure the drawbacks/benefits of the entire procedure.
stan
Old Jul 31, 2003 | 08:46 AM
turbo sol's Avatar
Default Re: battery location CRX (90crxsi)
if i am correct…
batteries produce hydrogen gas when they are charging and discharging. If a spark somehow finds a concentration of the ydrogen it can blow up. I have seen a battery blow before and its not good. I would strongly suggest a sealed gel type battery.
just some gen info for peeps.
Old Jul 31, 2003 | 09:33 AM
Default Re: battery location CRX (turbo sol)
you are correct, which is why a sealed, vented box is needed.
do i have one? no
i am getting a hawker battery so an expencive box is not nessesary
Stan
Old Jul 31, 2003 | 09:44 AM
GirlieRacer7o2's Avatar
Go buy the Moroso one. It's like $100 complete kit. I love mine. It passes NHRA Standards.
Also you need the battery cut off switch.
Old Jul 31, 2003 | 09:46 AM
Racer613's Avatar
I bought some 000 gauge wire from a fork lift supply store..(they had no red so I painted the end of the pos red) I got a plastic battery tie down box form AutoZone, the connections, and removed the spare tire in the Crx hatch. I then soldered the end ties to the wire, drilled a mounting bracket(holes) in the hatch, fitted the box, placed inside the Optima Battery, sent the wire through the inside of the car to the engine bay via drain plug? and connected. It starts up without hesetation, and there is no danger of the Optima blowing up and killing me or my Crx. I think the cables are 12' long each.... Good luck.
Old Jul 31, 2003 | 09:52 AM
Default Re: (Racer613)
The track over here wouldn't accept those Autozone boxes. I used to have one.. and they bitched at me. So I had to buy a new box.
Old Jul 31, 2003 | 01:33 PM
CRXRageD's Avatar
Default Re: battery location CRX (GirlieRacer7o2)
I started off with a marine battery box and later upgraded to a Moroso. I like the Moroso box lot better. Good luck finding it cheap though.
Old Jul 31, 2003 | 01:55 PM
Torino91LS's Avatar
Default Re: battery location CRX (CRXRageD)
I hate to ask this, do you notice a difference in cornering with the battery in the trunk? I guess it would be better for jumping off another car.
schueytenten
Oct 23, 2010 03:45 AM
wahee
Jun 2, 2006 02:06 PM
WTypeRogerX
Mar 18, 2003 01:11 AM
Renegade
May 21, 2002 01:20 PM
