hole in the firewall
Old Aug 6, 2001 | 11:28 PM
pho king guy's Avatar
Default hole in the firewall
ok i removed the firewall plug on the passenger side to run my power cable to my amp, and then lost the plug... does this cause anything detremental to the aerodynamics of the car, or am i just an idiot about to be flamed for asking this question? i can hear lots of air pouring into my car when i speed up, and it also sounds like the engine is sitting next to me all the time, so i keep thinking there's something wrong w/ my car... the part shouldn't be that hard to replace right?
Old Aug 6, 2001 | 11:45 PM
Chris's Avatar
Default Re: hole in the firewall (gan ni nia)
Water will get in. Replace it. Acura has a blow up of all the plugs in the firewall. Just point out what one you need.
Old Aug 6, 2001 | 11:51 PM
Default Re: hole in the firewall (Chris)
thanks, it's appreciated.. now i just have to get off my ***
[Modified by gan ni nia, 2:56 AM 8/7/2001]
Old Aug 7, 2001 | 05:38 AM
briq4's Avatar
Actually depending on the plug you used, there are really hard plastic ones and some are more "rubbery" if you take one of the more rubbery ones, and cut a small slit in it and push the power cable thru it makes a REALLY good seal. Even more than water being a problem, it can be really noisy. I never had water come through but it was really loud. Anyhow just a suggestion.
bmfbmf
Audio / Security / Video
Mar 28, 2012 07:37 AM
sho_shane
Feb 23, 2010 05:26 PM
newport45
Nov 28, 2008 03:56 PM
sk8shorty012
Jan 19, 2007 11:06 AM
dayaftertomorrow
Jul 19, 2005 09:01 AM
