RCA plug swap/replacement. help!?!
Old Nov 28, 2008 | 02:37 PM
newport45's Avatar
Default RCA plug swap/replacement. help!?!
So on the amp end of my wiring kit one of my rcas got smashed so i cut a plug off my old n64, when i cut off my rca from my car it had two thin wires coated separately whereas my N64 one just had one thicker wire. Can I combine the two smaller wires onto the thicker replacement?
or is it a totally different kind of rca plug, I have some double ended rca's from a home audio system, think one of those plugs would better fit my needs?
Old Nov 28, 2008 | 03:34 PM
It Wasn't Me's Avatar
Audio RCA's have two wires within each lead (left and right) to seperate positive and negative. Twisting the two together and attaching it to your N64 RCA tip will cause problems. You do not want to do that. Find another audio RCA cable and either adapt the tip to your existing cable, or better yet, replace the ruined RCA cable all together.
Old Nov 28, 2008 | 03:56 PM
newport45's Avatar
not trying to rip my car apart, haha but thanks for the tip i guess i'll have to get a legit plug
JockMehTeg
Audio / Security / Video
Jan 13, 2014 09:05 PM
Kicker2900
Apr 15, 2011 11:08 PM
Linked
Feb 15, 2010 07:27 PM
gomillion
Mar 7, 2007 04:51 PM
pat.ter.rick
Sep 6, 2005 05:53 PM
