installing my oil pressure gauge
Old Jul 30, 2003 | 08:32 PM
jisecup's Avatar
Default installing my oil pressure gauge
yeah, i know its been discussed before and before again, and i tried searching and blah blah
but anyway, where is it that i fit this fitting into on the back of the block? in refrence to what else?
Its mechanical gauge, and i have it ran thru and ready to go, the power and ground is all hooked up, but cant figurte out where to put it in the back of the block. And i read about the T fitttnig im suppsoed to use? where and what t fitting should i get?
Old Jul 30, 2003 | 08:47 PM
mr.beeks's Avatar
Default Re: installing my oil pressure gauge (jisecup)
take off your regular oil pressure sensor
wich is located to your left of the oil filter
the one with two plugs
buy the tee at local speed shop $5
you will place original sensor horizontal
and the nipple for the oil gage vertical.
hope this info helps
Old Jul 31, 2003 | 06:28 PM
jisecup's Avatar
yeah i can get it from ther, i just wasnt familiar with wher the stock oil pressure sensor was located.
thanks
Old Jul 31, 2003 | 06:40 PM
mr.beeks's Avatar
Default Re: (jisecup)
see where the line is coming out from
tee off from there.
Old Jul 31, 2003 | 06:54 PM
DeadLock23's Avatar
dont put the tee into the block, it will crack there, instead use a belted line loop it around then attach the tee to the line, from there connect whatever is needed to the tee includint the stock sensor.
Old Jul 31, 2003 | 07:04 PM
mr.beeks's Avatar
Default Re: (DeadLock23)
or a contraption like this one could work as well.
since im not creating an oil supply line to another equipment
a T should be just fine.
Old Jul 31, 2003 | 10:12 PM
l2Y4N's Avatar
Default Re: (francisco flores)
how important is it to retain the stock oil pressure sender? especially after haveing a gauge installed? btw, does anyone know at what oil pressure does the light come on?
Old Jul 31, 2003 | 10:57 PM
phat_gsr98's Avatar
Default Re: (integraTracer)
i've seen my oil pressure drop slightly below 20 psi and the light still wasn't on
i have in the past used one of those gay *** tee's it broke off in the block when i went to take it out but it was easy to get back out.
Old Aug 1, 2003 | 12:40 AM
JDMturboLS's Avatar
Default Re: (phat_gsr98)
(phat_gsr98)I've seen my oil pressure drop slightly below 20 psi and the light still wasn't on,
did it really drop down that far ?
Old Aug 2, 2003 | 02:59 PM
jisecup's Avatar
so i should get another fitting to put into the block then put the "T" on then hook up the gauge and the stock sensor?
Old Nov 19, 2003 | 09:25 PM
volkracing99's Avatar
New User
Default Re: (big reds)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by big reds &raquo;</TD></TR><TR><TD CLASS="quote">or a contraption like this one could work as well.
where is the wire from the oil sender? is that the green color thing?
thanks
Old Nov 19, 2003 | 10:00 PM
IN VTEC's Avatar
Default Re: (volkracing99)
It's on the bottom brass tee. Don't make me circle it.
The green thing is the ECT sensor.
OGMatt
Aug 15, 2011 01:11 PM
cjmitthun
75
Nov 21, 2006 08:35 PM
itsJDMyo
Feb 21, 2006 11:36 AM
carl_aka_carlos
Jul 16, 2002 06:49 PM
