would a 2001 b20z be obd2 or obd2.5?
I have a 2001 b20z in my 98 hatch and i'm curious if anyone knows which OBD version the motor would be. also, if it is OBD2.5, will I need to run a different computer or distributor set-up.
I am using a DX ecu and the wiring harness is the DX with a few plugs swapped for the correct amount of wires.
Modified by moike at 12:42 AM 7/31/2003
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by evilfred »</TD></TR><TR><TD CLASS="quote">If it is the same as for the civic, the plug to the ecu is different from the abd2a and obd2b...
keep in mind the car that the swap went into is OBD2 and that includes the wiring harness. the motor however is obd2.5 and i'm not sure if that will require additional work to make the motor adapt.
in other words, i'm not sure if i need to modify the distributor or use a different ECU?
i heart honda
Feb 13, 2009 05:11 PM
heel_touge
Apr 7, 2006 07:49 AM
