Air/Fuel Question?
Old Jul 30, 2003 | 06:33 PM
SadisticRacing's Avatar
Default Air/Fuel Question?
I just had a 68mm throttle body put on my car and also had my intake bored out. It seems to have to much air and we turned up the fuel but it still seems to be bogging down at low RPM. Plus the idle isn't smooth anymore, it bounces RPM's. I need advice on how to fix it or could the problem be because my intake is off right now?
Old Jul 30, 2003 | 07:37 PM
Yougod's Avatar
Default Re: Air/Fuel Question? (SadisticRacing)
make sure u adjust the idle properly when installing a new throttle body.
Old Jul 30, 2003 | 07:52 PM
976's Avatar
976
New User
Default Re: Air/Fuel Question? (Yougod)
Reset your ECU after every modification. Use search to learn how-to.
Old Jul 31, 2003 | 09:31 AM
hondaR's Avatar
have you check for a vacume leak?
Old Jul 31, 2003 | 11:28 AM
Default Re: (hondaR)
Thanks- resetting the ECU seem to solve the problem now it's just a little rough but that should go away when I get the intake back on.
pc122395
Jan 10, 2013 05:16 AM
wpk24rsx06
Sep 7, 2009 02:34 PM
Famous94LS
Apr 16, 2009 06:34 AM
blackh23
Jan 25, 2008 01:34 PM
Fly1865
Mar 31, 2003 11:24 AM
