91 da bouncing idle
Old Sep 7, 2009 | 01:46 PM
wpk24rsx06's Avatar
Default 91 da bouncing idle
hello im new here and my car is doing thishttp://www.youtube.com/watch?v=142PlYVP-1s
im thinking of just changing the intake manifold with all sensors see if that fixes the idle problem i checked the ecu codes and i got codes 7 throttle angle,14 electronic air control,16 fuel injector,17 vehicle speed sensor,and 43 fuel supply system. if anyone knows whats the problem or thinks intake swap would be good idea any positive input would be greatly appreciated.
Old Sep 7, 2009 | 01:54 PM
VerbalVenom's Avatar
Default Re: 91 da bouncing idle
Did you reset the CEL codes stuck in the ECU prior to checking the light for codes? Those could have been in there before you started having this problem. If you haven't cleared the codes, go ahead and do so THEN fire the car up. Take note of the CEL's after.
Old Sep 7, 2009 | 02:04 PM
wpk24rsx06's Avatar
how do you reset it
Old Sep 7, 2009 | 02:34 PM
bmcp.'s Avatar
Resetting the ECU.
According to the Service manual the ECU reset procedure is the following:
ECU Reset procedure. (Perform every time when troubleshooting)
1. Turn the ignition switch off.
2. Remove the BACK UP fuse (7.5A) from the under-hood fuse box for 10 seconds to reset ECU.
CANADA: Remove the HAZARD, BACK UP fuse (10A) from the under-hood fuse box for 10 seconds to reset ECU.
(The following is not found anywhere in the service manual, but makes sense, so I follow it.)
Now when starting the car, let the car idle for 5-7 minutes with all accessories off and don't press the accelerator at all. Let the car warm up to normal operating temperature before pressing the accelerator. REMEMBER DON'T PRESS ON THE GAS PEDAL UNTIL IT HAS WARMED UP FOR 5-7 MINUTES. When the car has warmed up for 5-7 minutes turn the ignition off. ECU has been successfully reset.
http://g2ic.com/tegtips/engine/5.html
BuiltF22
Sep 12, 2015 01:58 PM
pacificrim
Feb 15, 2009 08:56 AM
pro547
Mar 19, 2005 02:26 PM
GRANT!
Oct 26, 2004 11:59 AM
SadisticRacing
Jul 31, 2003 11:28 AM
