LS/VTEC ppl, maybe you can help.
Old Jul 30, 2003 | 06:00 PM
civicrtype's Avatar
Default LS/VTEC ppl, maybe you can help.
Thought I would get more help here https://honda-tech.com/zerothread?id=578327
Old Jul 30, 2003 | 06:25 PM
mmuller's Avatar
Mad Scientist
Default Re: LS/VTEC ppl, maybe you can help. (civicrtype)
no the ls manifold wont bolt on
you should upgrade to a gsr oil pump and vtec waterpump and yes use vtec timming belt.
if you use ls water pump then use ls timming belt
Old Jul 30, 2003 | 06:28 PM
torr's Avatar
i would recommend getting either a type r or skunk 2 intake manifold, which ever one is less expensive. also you'll a vtec water pump and vtec timing belt.
Old Jul 30, 2003 | 06:37 PM
civicrtype's Avatar
Default Re: LS/VTEC ppl, maybe you can help. (torr)
great thanks for the help fellas
Old Jul 30, 2003 | 06:39 PM
civicrtype's Avatar
Whats the best ecu to run? Should I use a chipped p28? and if so I can eliminate the knock sensor right?
Old Jul 30, 2003 | 07:40 PM
mmuller's Avatar
Mad Scientist
chipped p28 or p91, no knock sensor
Old Jul 30, 2003 | 10:11 PM
civicrtype's Avatar
Default Re: LS/VTEC ppl, maybe you can help. (mmuller)
what car does a p91 come from? it comes stock with no Knock sensor?
Old Jul 30, 2003 | 10:47 PM
mmuller's Avatar
Mad Scientist
p91 its like a p28, think is from edm
jedsus
Mar 13, 2008 08:38 PM
LSVTECJW
Oct 23, 2007 03:22 PM
DarkTeg94
May 31, 2005 07:21 PM
Battle Cat
Apr 30, 2005 10:21 AM
99EletronblueSI
Oct 19, 2004 11:13 PM
