s2k antena
Old Jul 30, 2003 | 03:23 PM
gumbybum's Avatar
Default s2k antena
does anyone know what is exactly needed for this swap? i have seen many threads about it but i cant find them anymore, please help...thanks
Old Jul 30, 2003 | 03:25 PM
xteg95's Avatar
Default Re: s2k antena (gumbybum)
http://www.bseries.net/html/garage/s2kantenna.php
Old Jul 30, 2003 | 03:27 PM
gumbybum's Avatar
Default Re: s2k antena (xteg01)
thanks mang
Old Aug 1, 2003 | 06:36 PM
gumbybum's Avatar
is there any other way to do the conversion than this way because i cant find any #10 5mm couplers or studs. everybody just says good luck finding metric around here.....WTF... can anyone help me out or am i going to have to tap some couplers and chase a stud my self
i really dont want to have to result to this
Old Aug 1, 2003 | 07:10 PM
gumbybum's Avatar
ttt
Old Aug 1, 2003 | 09:05 PM
xteg95's Avatar
did you try going to a honda dealership and getting them there?
Old Aug 1, 2003 | 09:27 PM
Pollux's Avatar
Everyone who says that must not have done the conversion. I had no problem finding everything I needed at home depot. And forget all about the pcp tubing at the whatever angle, totaly useless, all you need are the copling and like 3washes and 3 nuts if I remember correctly...
Old Aug 1, 2003 | 10:58 PM
gumbybum's Avatar
Default Re: s2k antena (Pollux)
man the homedepot, truevalue, blue collar supply and osh all didnt have what i needed.....did you just use the standard size and rape it on or what because they didnt have the metric size only standard....am i missing something here or is elk grove just anti metric?
Old Aug 1, 2003 | 11:34 PM
98LS4dr's Avatar
Will S2K conversion work on 4dr?
Old Aug 1, 2003 | 11:37 PM
00gsrBrynn's Avatar
i want one but do you think the reception is the same?
Old Aug 1, 2003 | 11:46 PM
gumbybum's Avatar
Default Re: s2k antena (00gsrBrynn)
yes it will work on a four dour and the reception is pretty good from what i hear as long as you use the radio coax thing like in the link provided..
Old Aug 1, 2003 | 11:51 PM
96 Ls lnTeG's Avatar
Where Can i Purchase this Atenna anyone Have Any Links??? 4 it??
Old Aug 2, 2003 | 12:23 AM
gumbybum's Avatar
Default Re: (sil2civic)
you can get them at any honda dealership or any place that they sell honda stuff
Old Aug 2, 2003 | 07:15 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gumbybum &raquo;</TD></TR><TR><TD CLASS="quote">is there any other way to do the conversion than this way because i cant find any #10 5mm couplers or studs. everybody just says good luck finding metric around here.....WTF... can anyone help me out or am i going to have to tap some couplers and chase a stud my self
i really dont want to have to result to this </TD></TR></TABLE>
There is no such thing as #10 5mm, #10 is a standard size and 5mm of course is metric. You have to buy a #10 coupler nut and then tap out half of it to the 5mm thread used on the S2K antenna. The other half of the coupler (still #10 thread) is used by the #10 bolt or threaded rod.
Instead of gluing a piece of angled PVC to a fender washer, I glued the angled PVC into a PVC endcap, and drilled a hole in the middle of the endcap. Works much better IMHO and it also reduces the amount of metal in the setup that might reduce reception.
Old Aug 2, 2003 | 07:17 AM
DB8_TEG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00gsrBrynn &raquo;</TD></TR><TR><TD CLASS="quote">i want one but do you think the reception is the same?</TD></TR></TABLE>
It should be about the same, but if you want the reception to be better get a radio ampplifier from like Radio Shack.
stonehawk_69
Feb 8, 2012 11:35 AM
loud3nergy
Feb 14, 2007 10:53 PM
Nate047
11
Aug 16, 2005 01:41 PM
Jared
Jan 29, 2005 10:48 PM
racer4life
Jul 28, 2004 09:55 AM
