y1 tranny grind
Old Jul 30, 2003 | 02:34 PM
silverCRXTC's Avatar
Default y1 tranny grind
i just got a jdm y1 and installed it in my crx, it has been sitting for 3 years and never used in the usa, it grinds into 3rd at any speed or rpm, sometimes it doenst also there is a winding out noise in 1st and 2nd, i use honda mtf in it, do u thing i should switch to gm syncro, or run the tranny for some time (i only got mabye 150 miles on it) and then change or u think its trashed?
thanks in advace
Old Jul 30, 2003 | 02:37 PM
drvfast's Avatar
Default Re: y1 tranny grind (silverCRXTC)
3rd gear syncro is bad
Old Jul 30, 2003 | 02:43 PM
JDMHN8's Avatar
Default Re: y1 tranny grind (drvfast)
Yep, you've got a bad synchro. DO NOT rebuild it, it's not worth it. Aside from the fact that you can't get any of the gear sets in U.S, the 1989-91 transmissions share no common parts with the 1992-01 transmissions. The Y1 LSD trannies are rather rare, though.
You're tranny is on its last legs. Better find a short YS1...
Old Jul 30, 2003 | 03:10 PM
Default Re: y1 tranny grind (JDMDA9)
u can get the syncro kits dave (jdm dohc vtec i think) but i wonder if any one else has had this happen and it was just needed some time to break in
Old Jul 30, 2003 | 03:21 PM
Benny Hinn's Avatar
it happens to everyone.
not breaking in, worn out.
Old Jul 30, 2003 | 03:59 PM
JDMHN8's Avatar
Default Re: y1 tranny grind (Benny Hinn)
Try changing the tranny fluid. I changed mine and the 2-3 grind in my LS YS1 became far less severe. Honda MTL is good but I've heard that $9 a bottle GM Synchromesh Friction Modified can help out even more severe grinds.
Old Jul 31, 2003 | 03:59 PM
look at this page.
tell me what u think
http://courtneyeg9.streetracin....html
Old Jul 31, 2003 | 04:04 PM
Blaze45's Avatar
Brrraaaap!
Try the GM sync stuff. Worth a shot.
Blaze
jdmstyleEJ6
Jun 13, 2010 06:08 PM
Honda Sport
Mar 20, 2006 02:12 PM
Groove_D
May 1, 2004 12:46 AM
RagingAngel
Nov 8, 2002 07:13 PM
ill phil
15
Sep 4, 2002 10:37 PM
