Flat towing
keep it in neutral... keep very light pressure on the brake of the car being towed, to keep slack out of the tow-strap line.
...wondering if this is the kind of flat tow you're talking about.
With a proper tow bar, you want the steering lock disabled (which a racecar should have anyway) so the car can steer to corner behind the tow car. it can't wander as it is hard linked to the tow machine.
I have never done any real flat towing of a Honda. I don't know any specific mechanical issues that a Honda would have although some cars will suffer troubles because of it. If you flat tow a Corvair about any distance or even have the rear wheels on the ground with the front in the air on a normal wrecker, the camshaft will fail within 1000 miles of use later. Don't know why, just some bad mojo I suppose. I haven't heard of such on a Honda but that is not to say it can't happen.
yeah i know greg flat tows, he didnt seem to have any problems with it at all. just looking for others ppls opinions. the wear on the suspension and tranny i guess are what i want to know if its negligable(sp?).
Can you back up if it's hooked up in a flat tow?
Plus, well... cars aren't all too keen about being flat towed if the suspension is busted, or if the wheels point in 4 different directions, not that I've ever had that problem...
Warren
Warren
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Warren »</TD></TR><TR><TD CLASS="quote">Can you back up if it's hooked up in a flat tow?
Warren</TD></TR></TABLE>
You can always DRAG a hunk like that home...I hear chad is all into draggin chit...
