Consequence of letting the CV joint destroy itself???
Old Jul 30, 2003 | 01:28 PM
Cosworth's Avatar
Default Consequence of letting the CV joint destroy itself???
What is the consequence of letting the CV joint destory itself? I know it sounds dumb, but I do not know the mechanical consequences of such an event.
Would it seize all of sudden and cause the car to veer off the road?
Or, what would happen?
Thanks,
Sean
Old Jul 30, 2003 | 02:08 PM
Propulsion's Avatar
Default Re: Consequence of letting the CV joint destroy itself??? (Cosworth)
I think the teeth would wear out and not catch... you wouldn't go anywhere.
Old Jul 30, 2003 | 02:12 PM
STOLEN - ITR 98-0652's Avatar
I had the axle literally fall out of the joint on my old Subaru. You need to make a pretty tight turn to have that happen, though... You'll know way (WAY) before it's at that juncture before it happens. When it clicks ALL the time (not just turns or on/off load) it's gone and it will fall out of the joint at any opportunity. Theoretically, this could happen on the road and the axle will catch on the pavement, destroying the output spline and the transmission in the process.
So, on second thought... when you knowi t's bad - replace it before it fails on you in motion.
Old Jul 30, 2003 | 02:27 PM
SlapSmak's Avatar
if the CV joint fails/fractures at the hub end, it could remain connected at the transmission end. At speed, the shaft would then immediatly spiral out, being carried outward with the centrifical force. the end of the shaft would then hit every part of the suspention that was exposed and then lodge towards the rear of the car. The sudden stop (deceleration trama) created by this stop would effectively rip the still connected transmission side of the CV joint from the tranny, most likely taking a nice sized chunk of the tranny case with it. If it fails/fractures on the tranny side, the Joint/hub on the trans side simply breaks at the pivot point and the CV spins freely, usually creating no damaging aftermath, you just cant move forward and hear a nice clicking sound. I have seen it both ways, and the first isnt pretty. CVs are like 100$, fix it now.
Old Jul 30, 2003 | 04:23 PM
Default Re: Consequence of letting the CV joint destroy itself??? (SlapSmak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlapSmak &raquo;</TD></TR><TR><TD CLASS="quote">being carried outward with the centrifical force</TD></TR></TABLE>
Centripital Force
There is no "Centifugal Force" and certainly not a "centrifical force".
Don't mess with a dork.
Old Jul 30, 2003 | 06:05 PM
D's Avatar
D
Default Re: Consequence of letting the CV joint destroy itself??? (ITR 98-0652)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR 98-0652 &raquo;</TD></TR><TR><TD CLASS="quote">There is no "Centifugal Force" and certainly not a "centrifical force".
Don't mess with a dork.</TD></TR></TABLE>
i ******* hate it when people say "centrifugal"... retards.
Old Jul 30, 2003 | 08:32 PM
Tweakmeister's Avatar
Default Re: Consequence of letting the CV joint destroy itself??? (D)
Just for you D
Old Jul 31, 2003 | 03:57 AM
GM2000ITR's Avatar
New User
Been there, done that. Of course, this was a stock axle (w/ less than 10k miles on it). I snapped this one at the track (2nd launch). LS/VTEC w/ maybe 180-185 whp (have not yet dyno'd), 2550 lbs. w/out me in it, 205/40/17 at a full 33psi.
I snapped it's replacement on the street not 3 months later. That one, however, suffered a more painful destruction: it shattered the CV joint (into what sounded like the liquid terminator when it was frozen and had a shotgun shell pumped into it) when I hit 2nd gear on the way to work one morning. I didn't loose control, just power(when I opened the throttle, the rpms would just climb as if the car were in neutral and the portion of the axle still attached would just rattle around inside the wishbone). I guess I just have bad axle luck!
Old Jul 31, 2003 | 04:53 AM
Brandon Clifton's Avatar
"Because the centrifugal force exists only in rotating reference frames, but not in inertial reference frames, it's sometimes called a "fictitious" or "pseudo" force.
We don't like this characterization because there is nothing fictitious or pseudo about it when your car goes off the road and crashes... The Earth's equatorial bulge is not a fiction, nor is the problem an engineer confronts when designing turbine blades of jet engines that have to stay together at rotation rates of up to 100,000 revolutions per minute."
http://observe.arc.nasa.gov/na....html
And I should know, I'm an engineer who designs those 100,000 rpm turbine engines. (centrif is outward, centrip is inward)
AAAnyyway- yes, if you let an axle come apart the consequences are dire. The other scenario that no one explored would be if it wore out and didn't fly apart, you are putting all of the engine torque through one side of the diff- which will wear it prematurely.
Old Jul 31, 2003 | 11:07 AM
CW-ITR's Avatar
Default Re: Consequence of letting the CV joint destroy itself??? (ED3-D15T)
_______
Some time, it does take a rocket sientist to settle an argument like in this case.
Old Jul 31, 2003 | 12:01 PM
Trey's Avatar
25 Year Member
You are the most paranoid person I've ever known.
Old Jul 31, 2003 | 01:53 PM
Chris's Avatar
Default Re: Consequence of letting the CV joint destroy itself??? (Trey)
I have driven an integra with really bad axles.
Under a load the wheel shakes, as the one bad axle grinds itself into shavings, There was no more boot left at all, and once I pulled the ball joint out, the inboard joint fell onto the ground in little pieces.
I doubt it would sieze, but it could sure become a road hazzard as pieces fall out, and if you were to lose drive on one wheel under a heavy load, you may veer to one side (like torque steer kinda).
Corksil
Nov 23, 2009 01:30 PM
grkblood13
Transmission & Drivetrain
Apr 2, 2009 05:09 PM
CRJenkins13
Nov 7, 2007 05:18 AM
Rooftop voter
Suspension & Brakes
Apr 9, 2007 08:38 AM
JinteDgraM
Mar 8, 2004 08:47 PM
