brake fluid/ebrake light
Old Jul 30, 2003 | 10:12 AM
Sam268's Avatar
Default brake fluid/ebrake light
my brake fluid in the mc is a bit low.. would that effect the ebrake light. it comes on and off especially if i pull the car in first or during accelation. once the car is kinda on level ground in 3 or 4th gear going smoothly. it goes away and comes on and goes away. I already checked the ebrake connector and is fine.
any suggestion?
Old Jul 30, 2003 | 10:25 AM
Perfectionist's Avatar
Default Re: brake fluid/ebrake light (Sam268)
Yes, the light will come on if the fluid is low enough. Yours goes on and off as the fluid sloshes around during acceleration.
BTW, if you don't have any leaks, low fluid indicates worn brake pads/components.
Old Jul 30, 2003 | 10:26 AM
turbochic's Avatar
well first figure out why your brake fluid is low, worn pads...leaks????
there is a sensor on the reservoir car that senses fluid level and when it is low, the light will come on, obviously if it swishes around it will go on and off.
do not just refill the reservoir, brake fluid does not evaporate, so figure out why it is low, if it is worn pads, relace them and your fluid level will most likely rise, if its a leak then you should fix it (duh) and then refill the reservoir....
hope that helped just a bit...
Old Jul 30, 2003 | 10:29 AM
Crisgo's Avatar
Default Re: brake fluid/ebrake light (fmaxturbochic)
I recommend what was stated above and also replace the m/c cap if the light does not turn off
Old Jul 30, 2003 | 11:01 AM
Sam268's Avatar
thanks guys. I had to flush my brakes a bit after putting on new rotors and pads and didn't know I was out of fluid. so I will get some today to fill it back up. I flush till it was close to the lower mark or else I would of have almost no brakes.
hope this goes away when I fill the fluid back up.. thanks all for your advice and conern. but I still have a problem taking out the caliper pins. are the pins on the caliper and do it remover the pin from outside of the caliper where the 2 12mm screw goes in. the pins are with treads for the bolt to go in right.
type-GGSR
Jan 28, 2008 11:22 PM
jjr_99prelude
Aug 31, 2007 09:23 PM
Z7
10
Aug 6, 2006 01:17 PM
Ha7chB4cK
May 3, 2005 06:06 PM
white_R98
Dec 11, 2002 07:39 AM
