code p0133
Old Jul 30, 2003 | 10:04 AM
ramz7887's Avatar
Default code p0133
Can anyone help me with this. Do i need a new ecu? If so what kind for a 98 civic ex?
Old Jul 30, 2003 | 10:41 AM
EE_Chris's Avatar
Default Re: code p0133 (ramz7887)
Here is a neat little code checking utility someone showed me:
OBD1 & 2 Code Checker
P0133 seems to be related to your O2 sensor.
Old Jul 31, 2003 | 02:21 PM
ramz7887's Avatar
thats a good site thanks a lot
Old Aug 2, 2003 | 05:45 PM
AngryTroll's Avatar
P0133------->O2 sensor slow response
It will probably need an updated computer. It's a warranty item for 8 years or 80,000 miles...
Old Aug 3, 2003 | 08:13 AM
EE_Chris's Avatar
Default Re: code p0133 (AngryTroll)
I know the OEM must warranty their catalytic converters for 100k miles, I do not think that same warranty applies to the O2. Just beuase the computer says it has a slow response does not mean the ECU is bad. The O2 can become clogged up and lazy over time.
Old Aug 3, 2003 | 03:47 PM
ramz7887's Avatar
i replaced the 02 sensor a year ago and the dealer told me that if my o2 sensor was new then the only other problem must be the ecu.
Old Aug 3, 2003 | 05:00 PM
AngryTR0LL's Avatar
Maybe my response wasn't clear. Honda has a service bulletin to fix this problem (#99-049). If you have under 80K miles on your car, Honda will pick up the bill.
If you have more than 80K, you'll pay about $1000 parts and labor...
Old Aug 4, 2003 | 01:13 PM
ramz7887's Avatar
Default Re: code p0133 (AngryTR0LL)
i have a 106,000mi
Old Aug 4, 2003 | 01:14 PM
ramz7887's Avatar
i was told that i could get a used ecu for 50 or so and that the install was just plug and play. Why would it cost a 1000 plus from the dealer.
Old Aug 4, 2003 | 03:25 PM
AngryTR0LL's Avatar
A new computer from the dealer is a little over $800.00. Labor and tax will get you to about $1000.00. Keep in mind the new ECM will be an update to fix this problem. If you buy a used computer, chancer are you'll have the same problem.
If I were you, I would just clear the light and drive. It may be another year before you set the code...
-Troll-
Old Aug 4, 2003 | 07:11 PM
na200whp's Avatar
just clear it if you are only getting this code once a year who cares . honda has ecu's that just reduce the sensitivity of that sensors imput.it will not make your car run better .discout auto parts (advanced auto)clears codes for free.if it becomes a constant problem then concider the new ecm.
SpoonCivicSir20
10
Mar 29, 2009 10:14 PM
Koyoloeor
Oct 13, 2005 04:57 PM
Eucalyptus lude
Jun 3, 2005 01:42 PM
EFSiR
Mar 12, 2002 02:33 AM
civichybridb16a
Jul 29, 2001 06:34 PM
