cam shaft installation
i recently pulled the head off for a blown head gasket...
and im not sure how to put the cam shaft back on.. i know if im off by alil my timing will be all wak and blow sumthing else...
i think u just put the piston at tdc and also the cam shaft... i just want to make sure if im right
set the crank to TDC (there is a mark by the crank pulley also) then set both cam shafts (or one if you have sohc) to tdc as well, retention the belt, tighten the tentioner and your done.
