Who has had a bad experience w/ Redline Tranny Fluid?
Old Aug 6, 2001 | 04:51 PM
Rain_man's Avatar
New User
Default Who has had a bad experience w/ Redline Tranny Fluid?
I'm trying to decide b/t honda or redline... I'd prefer to get synth, but I recall some people not liking it...
Old Aug 6, 2001 | 05:10 PM
SMSP's Avatar
Default Re: Who has had a bad experience w/ Redline Tranny Fluid? (Ein)
I don't like the MTL and run the 75W90 but I have a Quaife.
Old Aug 6, 2001 | 05:53 PM
ha-evolution's Avatar
New User
Default Re: Who has had a bad experience w/ Redline Tranny Fluid? (SMSP)
I don't like it either, at least not in Honda's. I put it in my 94 Prelude V-tec and it was too slippery. It made the grinding from my worn synchro in 5th gear even worse.
Old Aug 6, 2001 | 06:10 PM
GSR_Hacker's Avatar
New User
I spoke to the techs at Acura who I know pretty well.... Use ONLY the honda MTL. The others do not help at all. They will affect the syncros. Just an FYI.
Old Aug 7, 2001 | 01:03 AM
keys's Avatar
Default Re: Who has had a bad experience w/ Redline Tranny Fluid? (GSR_Hacker)
i know, my opinion is that MTL sucks... used for about 3 months, then i started to feel my gears grinding
Old Aug 7, 2001 | 03:07 AM
1fastGSR's Avatar
New User
Default Re: Who has had a bad experience w/ Redline Tranny Fluid? (keys)
I"ve been using it for 6 months and no problems! I also used it in my 96LS w/ NO problems! I don't know what you're doing to your trannys to make them grind!
Old Aug 7, 2001 | 04:48 AM
Shmeek's Avatar
Default Re: Who has had a bad experience w/ Redline Tranny Fluid? (1fastGSR)
I've been using Redline MTL for about 3 years now. No problems what so ever. The MTL fixed a problem I had getting the car into first when the car was moving. It's much easier to do now.
FYI Honda MTL is a synthetic, so chances are the gains going to Redline would be small. I went with Redline just because I was trying to fix a problem.
Old Aug 7, 2001 | 08:39 AM
90integraGS's Avatar
New User
Default Re: Who has had a bad experience w/ Redline Tranny Fluid? (Shmeek)
We're talking about oil for a manual transmission, right? I went to FRANK ANCONA HONDA in Olathe, KS yesterday to get some Honda manual transmission oil. The kid at the counter said he just sells 5-30 engine oil for that purpose and there is no such thing as Honda MT oil anymore.
What's the scoop?
Old Aug 7, 2001 | 12:21 PM
New User
Default Re: Who has had a bad experience w/ Redline Tranny Fluid? (Teken)
Yup
Old Aug 7, 2001 | 12:27 PM
KL's Avatar
KL
New User
Default Re: Who has had a bad experience w/ Redline Tranny Fluid? (90integraGS)
The "older" Hondas, including G2 Integra (90-94) called up 10W30 motor oil for the transmission.
The G3 Integra shop manual called up Honda MTL, but does say in a pinch motor oil can be used, however it should be replaced with MTL as soon as possible.
I would tend to believe Honda engineer when they say motor oil should be avoided in the newer manual transmissions.
Old Aug 7, 2001 | 12:31 PM
Vazquez911's Avatar
Default Re: Who has had a bad experience w/ Redline Tranny Fluid? (KL)
Just changed mine... and you want to know what I used, and is working awesome... GM Synchomesh... designed for the big 6-speeds in the Vettes, etc.
GOOD STUFF!
Old Aug 7, 2001 | 01:59 PM
cannon_man's Avatar
New User
no i just bought MTF from a honda dealer the other day. they had to order it for me too, so, that guy is a f4rking moron.
cannonman
[edit]yes its genuine honda mtf
[Modified by cannon_man, 6:00 PM 8/7/2001]
Old Aug 7, 2001 | 04:55 PM
stick's Avatar
ive had Redline MTF in my teg for over 2 yrs and no probs,
also got rid of my 5th gear synchro grind
it is a little stiff tho in cold weather
WILD_WILL
Honda Civic (2006 - 2015)
20
Dec 24, 2007 06:05 AM
94IntegraLs04
Oct 10, 2004 02:42 PM
THMotorsports
Sep 14, 2004 06:25 AM
Tex Blackwell
Aug 14, 2004 11:10 PM
ChingonGSR
Apr 18, 2003 11:16 AM
