Problem with VTEC..
Old Aug 5, 2001 | 08:13 PM
GSlowR's Avatar
Default Problem with VTEC..
OK tonight i tookout my sub box so I could test to see how much 'peppier' my car would feel(that **** is staying out) .. well i ran into a civic and when we were racing I swear I felt my engine lose power right before it hit vtec... like your normal engine would sound like this wahhhhhhhhhhhhhhh-AHHHHHHHHHHHHHHHH .. the second part being when vtec kicks in.. well my car was sounding like this wahhhhhhhhhhhhh-ah-AHHHHHHHHHHHHHHH...
any ideas what could be wrong?
bad tuning or what?
I have i/h/e, cam gears, v-afc, denzo plugs..
Old Aug 5, 2001 | 08:35 PM
Jesse H's Avatar
Default Re: Problem with VTEC.. (GSlowR)
FYI
the audible change in intake/exhaust noise are the intake runners, not cam crossover. You can hear the cam crossover, but it's just not as distinct.
Old Aug 5, 2001 | 08:46 PM
GSlowR's Avatar
Default Re: Problem with VTEC.. (Jesse H)
well what I'm saying is it doesn't sound like it should.. it seems like there is a slight loss in power for a second...it doesn't seem normal.. that's all i'm saying.. is it a fuel problem? is my v-afc messing something up? is it a problem with oil? i'm clueless i don't need to be informed of what the REAL sound is from.. i feel a loss in power where my engine almost sounds like it cuts off for 1/2 a second..
Old Aug 6, 2001 | 12:51 AM
ingrate's Avatar
25 Year Member
Your VTEC engagement point is probably too early.. what RPM does it kick in at?
Old Aug 6, 2001 | 01:38 AM
GSlowR's Avatar
Default Re: Problem with VTEC.. (In7egrity)
i'll have to check the v-afc i remember they lowered it when i got it dynoed.. guess they don't know what they are doing.. i'll get back to you on that..
Old Aug 6, 2001 | 07:38 AM
Dawsonb17a's Avatar
New User
no no no, there's nothing wrong with your v-afc. I've noticed the same thing happening with my car sometimes. It feels like a dip in the powerband right before you hit VTEC (at least in my car, since I've got the b17a). The only explanation I can come up with is that it usually happens when its extremely humid outside, so I attribute the power loss to the weather.
Old Aug 6, 2001 | 08:28 AM
Rory Breaker's Avatar
Have you checked your maintenance? How many miles are on the car?
Old Aug 6, 2001 | 08:57 AM
Seedc2's Avatar
haha I aint sure about the problem but just wanted to make a quick comment on your post.. haha I love the way you explained the vtec part.. wahhhhhhhh-AHHHHHHHHHH~~~!! i love that sound
Old Aug 6, 2001 | 11:39 AM
GSlowR's Avatar
Default Re: Problem with VTEC.. (newgsrdriver)
yes I am at 38000 miles and I got my 30k maintenence.. around 33k.. and about the vtec engaging too early.. i didn't remember the exact numbers but it was like 4500-4800?
seems kinda low.. but that's what they set it at when I got my car dyno-tuned
Old Aug 7, 2001 | 04:31 PM
WOT's Avatar
WOT
New User
Look @ your dyno graph and see if there are any dips on the curve. If you still have the stock GSR cams you should leave your vtec x-over point stock. That would be 4400 rpm. Go to your V-AFC and set L->H 4400 & H->L 4000, that's about stock I think. You should only use a different vtec point if you upgrade cams. Good luck.
Old Aug 7, 2001 | 05:08 PM
PROFILES2000's Avatar
Default Re: Problem with VTEC.. (WOT)
check yer oil pressure.....are u due for an oil change? vtec has a lot to do with oil.....good luck
97dc2
Sep 12, 2005 09:10 PM
teg969
May 9, 2005 09:21 AM
civicSIracer96
Jan 12, 2004 10:31 PM
EGtoR
Jan 19, 2002 11:27 PM
GTEater
Jun 15, 2001 03:49 AM
