CEL question
Old Aug 6, 2001 | 03:02 PM
JSpecwest's Avatar
New User
Default CEL question
When your engine throws a CEL, does the ecu ever compensate for anything and make your engine run differently? I have a 98 Type R and the check engine light is 45, having to do with the fuel mixture. Thanks...
Old Aug 6, 2001 | 04:00 PM
LostGsr's Avatar
Default Re: CEL question (JSpecwest)
I believe when you engine throws a CEL, the car goes into limp mode. For sure it won't engage the vtec.
Old Aug 6, 2001 | 04:36 PM
BreakStuff's Avatar
New User
[QUOTE]When your engine throws a CEL, does the ecu ever compensate for anything and make your engine run differently? QUOTE]
Just had to make me stop and think JSecwest..
Thats a good damn question.. I would have to say "yes"
but I don't think that was mandated by the EPA when OBDII came to be, and it may be different with other car manufacturers.. I guess it would depend upon the car.. Maybe when OBDIII comes around the ecu will have more "functionality" to correct whatever problem it may be seeing.. OBDII is is more of a monitor and record type function..
lets do a little test..
I do believe the ecu can compensate.. I can only think of one component that can "physically" control the motor and make adjustments to compensate.. anybody know what component has that capability?
And whats its function with a normal running motor?
I'm gonna make you people think for a change!..
[Modified by BreakStuff, 5:07 AM 8/7/2001]
renzis00
25
Sep 24, 2012 09:47 PM
Si_Guy2000
37
Jun 14, 2009 03:48 PM
megaman096
Oct 25, 2004 05:27 PM
DumpedSi
Aug 20, 2003 03:40 PM
kpxgq
Apr 16, 2002 10:20 AM
