still need help/ with codes 6 and 14.
Old Jul 29, 2003 | 10:00 PM
PhatHatch89's Avatar
Default still need help/ with codes 6 and 14.
My car is throwing codes 6 and 14. the car runs like crap. As soon as it warms up it starts to spudder and then wont run past 3 grand. does anyone know why it does this? I need my car fixed so I can get back and forth to work. Please help thanks again branden
Old Jul 31, 2003 | 12:25 AM
Default Re: still need help/ with codes 6 and 14. (PhatHatch89)
can a bad alternator cause my sensors to throw codes? The reason I ask is that all of the sensors run off of different voltage. And if the voltage drops due to a bad alternator and a battery running low, the voltage will not be there to power the sensors. I dont know if this would cause anything, but if anybody know please let me know. Thanks
Old Jul 31, 2003 | 09:18 AM
TypRice's Avatar
code 6 is the crank angle
code 14 is the Electronic air control
change your distributer ...the crank angle is internal in the dis...
i had the same prob. a while a go.
Old Jul 31, 2003 | 09:23 AM
Default Re: still need help/ with codes 6 and 14. (TypRice)
thanks will change the distributor. What should I do about the eavc valve?
daklown
14
May 23, 2007 10:13 PM
Sportyballade
Oct 27, 2006 05:05 AM
Si Jeff
27
Dec 20, 2005 05:34 PM
AllMotorBrew
Dec 11, 2003 10:37 AM
PhatHatch89
Jul 28, 2003 08:34 AM
