suspension problem
Old Jul 29, 2003 | 08:02 PM
goose12's Avatar
Default suspension problem
can anybody tell me wut is wrong wit my suspension...when ever i go past 10 mph my steering goes out of control my camber is way off but i shouldn't lose control like that....the wheels turn left and right. thanks
Old Jul 30, 2003 | 02:41 AM
ryanstev's Avatar
Default Re: suspension problem (goose12)
Have you had your wheels balanced? That's the easiest thing to check.
Old Jul 30, 2003 | 10:58 AM
goose12's Avatar
Default Re: suspension problem (ryanstev)
i haven't but that can't be the problem....i really lose control and i can't really gain steering back until i slow down
Old Jul 30, 2003 | 11:03 AM
1_bad_EF's Avatar
i sounds like something broke. for ***** n giggles kick the front and back of the front wheels to see how much they move. They are not supposed move much at all. Did you just lower the car or did this just happen?
Old Jul 30, 2003 | 02:57 PM
goose12's Avatar
Default Re: (1_bad_EF)
well i jus bought the shell and i didn't knO what was wrong wit it but i still got it cuz it was cheap as hell......but its pretty much slammed....my header is about 1 inch off the floor.....imma raise the car and see what happens..but u have any other suggestions as to what the problem might be....i took a look at the suspension and everything looks fine thanks
Old Jul 30, 2003 | 03:10 PM
Prelude Vtec 23's Avatar
Default Re: (goose12)
How new are your tires? If your tires are wearing down they can cause the steering wheel to move like crazy also.
Old Jul 30, 2003 | 04:52 PM
Mohudsolo's Avatar
Default Re: (Prelude Vtec 23)
Check toe. If dropped a bunch, you could have a bunch of toe out at both ends. Could also have other problems, jack it up and try moving the wheels up, down, left, right. Any play other than the steering wheel moving is bad. Check everything that pivots, A-arms, shock links, ball joints, wheel bearings. Is the car so slammed that there is no suspension travel? Could be on the bump stops which would not do the rest of the suspension any good either. Make sure the axles are not bound up.
Old Jul 31, 2003 | 02:55 AM
DCStreetHtch's Avatar
Default Re: (Mohudsolo)
sounds like you bought yourself someone else's problems my friend.... get your **** on a lift and do an inspection!!! good luck!
-Bryan-
Old Jul 31, 2003 | 12:14 PM
goose12's Avatar
Default Re: (EGStreetHtch)
Thanks everybody I'll check it out
Old Jul 31, 2003 | 12:40 PM
mmuller's Avatar
Mad Scientist
steering rack ok?tie rod ends ok?
Old Jul 31, 2003 | 02:07 PM
goose12's Avatar
Default Re: (mmuller)
i jus out in a new steering column in but it seems like the problem is coming from the suspension...
seatownda9
May 12, 2011 07:24 PM
turbodtaylor
Mar 23, 2010 10:24 AM
ThatsMyEG
Jul 1, 2005 04:43 PM
Ditdogs
Mar 29, 2004 03:10 PM
dan89crxsi
25
Jan 27, 2004 03:29 PM
