experience needed.....what boost can my built d-block take
Old Jul 29, 2003 | 07:17 PM
VTgringo's Avatar
Default experience needed.....what boost can my built d-block take
I am purchasing a mini me with a 91 d16a6 block and a d16y8 head. the engine was rebuilt by professionals new bearings gaskets belts, LS rods, and brand new 9:1 compression DX pistons. The head has a stage four port and polish with a three angle valve job. I will be running a junkyard turbo setup with a t25, starion fmic, dsm 450 injectors and zdyne engine management. My last fully built zc (built by me) lasted one day (i reused old bearings on new crower rods). I really don't want this to happen again. My turbo is set at 10psi and i would boost any higher than that, will my engine survive? any experience with a similar setup? I still have the 9:1 JE forged pistons for the zc, should i throw those in? I know the have the same bore but i think the CR would be somewhere around 10 or 11:1. I might even be able to throw the whole setup with the crower rods and JE pistons if they weren't damaged when my zc spun a rod bearing (might have to be machined). Thanks for everyones expert advice i know there are some experienced people on this forum
Old Jul 31, 2003 | 12:39 AM
VTgringo's Avatar
Default Re: experience needed.....what boost can my built d-block take (VTgringo)
please help....i'll try bumping this tomorrow
Old Jul 31, 2003 | 03:33 AM
7PSiEF9ZC's Avatar
I was running a WRX turbo on my Stock ZC at 8 PSi. I dropped a valve and blew the whole motor. Really if it's a daily driver I wouldn't boost more then 8 or 9 EVEN if the motor can take it. First A honda at even only 2 PSi is faster then alot of street cars. Second there will always be a weak link somewhere. The higher boost the greater the chance of something blowing. I've seen stock LS/VTec's take 10-12PSi when tuned right. If your asking if you can push higher then 10 with everything you have done to the motor Yes but I would not do it for long until it's tuned to be running higher then that really.
Old Jul 31, 2003 | 03:35 AM
7PSiEF9ZC's Avatar
Default Re: experience needed.....what boost can my built d-block take (7PSiEF9ZC)
After re-reading your post .Now are those just stock LS rods and stock Dx pistons being used for forged units. IT it's stock internal ( i.e. stock parts from other motors ) I'd say NO way boost that high with it. I have seen stock D series push 10 PSi daily driven but they are far and few
Old Jul 31, 2003 | 08:33 AM
VTgringo's Avatar
ok........so do you know what my best option for turning the boost down on the turbo is. the wastegate is set at 10psi, i know i can modify that rod that opens the wastegate but i really don't want to do that. I was thinking of setting the bov to 6-8 psi....its getto but it should do the trick. any commments to this. thanks
Old Jul 31, 2003 | 08:51 AM
turbo sol's Avatar
stock LS rods are fine, teh pistons i dont know about i woudl swap them if you can.
I run LS rods and SRP 9:1 and i plan on 10psi daily.
how did you get the stock pistons on the LS rods? that wasnt a possibility when i did mine.
LS rods are way bigger than d16 rods for those who doubt about there strength.
Old Jul 31, 2003 | 07:26 PM
VTgringo's Avatar
Default Re: experience needed.....what boost can my built d-block take (turbo sol)
whats the worst situation that would come out of piston failure due to boost (realistically speaking). I still have my 9:1 JE/Crower setup that i can swap in. I just don't have the time to get them back in before school starts. I was planning on boosting 6-8psi and if a piston cracks or i get ring failure I could put the crower/JE's in.
knightsef-eg
Aug 9, 2009 04:53 PM
Arch-Angel
Sep 10, 2003 10:35 AM
VTgringo
Jul 26, 2003 11:29 PM
VTgringo
Jul 24, 2003 06:01 PM
VTgringo
May 27, 2003 03:02 PM
