built turbo zc engine seized
Old Jul 24, 2003 | 04:10 PM
VTgringo's Avatar
Default built turbo zc engine seized
i just finished putting my t-25 turbo on my built zc that i had driven for about a year with no problems. about a day after the turbo went on the engine seized. I installed crower rods with JE 9:1 comp pistons. My problem is that i used the old rod bearings when i rebuilt the engine (my best guess without taking off the oil pan) I know I'm a ******* idiot....so please don't just talk ****. Next time i drop all my money into a motor i will do it right. My question is if i spun a rod bearing what will be shot in my engine. My guess is the crank and the rod thats stuck. Does anyone think that i could possibly get the rods machined and be ok? Would i be better off getting a new zc? I really though i was mechanically inclined to rebuild the engine by following the haynes manual.....i guess next time i will do more research. Thanks for the help H-T!
Old Jul 24, 2003 | 04:12 PM
Garrett's Avatar
If a bearing broke everything could be damage, like pistons rods, crank
Old Jul 24, 2003 | 06:01 PM
quis23's Avatar
Default Re: (Garrett)
your best bet is to tear it down and check the damage. i just spun 2 rod bearings in my zc and it was cheaper for me just to by a new zc than to rebuild . just remember , whatever you do -do it right ! and spending a little $$$ now can save a shitload of $$$ in the long run.
luis253
Feb 12, 2015 10:11 PM
VTgringo
Jul 24, 2003 09:33 PM
Hulkbuster
20
Feb 18, 2003 11:49 AM
travis_118
Mar 24, 2002 12:03 AM
