o2, 4 wire, white, white, grey, black, will it work with P28 + hondata?
The two whites are the heater grounds, the grey is your signal wire and the black is the ground. So the two whites=two black wires, grey=white wire and black=green wire. The sensor sounds like a bosch replacement o2 sensor, they do work.
thank you !, now are you familiar with hondata?
i have a p28 ecu from hondata, the led in hondata will be solid, until i plug the serial cable into it, than it will blink slowly.. .
and i can't get the hondalogger to recognize that it's connected.. it just says serial # s00-00000
laptop is setup right, fifo turned off.. any thoughts?
2 o2 sensors, same connectors
the grey wire is in the same position as the green wire on the connector
elmalouno
11
Aug 18, 2004 09:06 AM
