nosing in vtec
Old Jul 29, 2003 | 12:30 PM
ferio 95's Avatar
Default nosing in vtec
my gsr swap is still kind of new for me but i just want to know with a zex wet system will nosing in vtec be a good idea. i just don't want to put to much strain on the block..
Old Jul 29, 2003 | 12:35 PM
arw321's Avatar
Default Re: nosing in vtec (ferio 95)
What the hell does "nosing" mean?
Old Jul 29, 2003 | 04:02 PM
CircuitFG's Avatar
Default Re: nosing in vtec (arw321)
i think he meant squeezing. . . .NOS'ing. . . .and I dunno. . i'm not really big on the whole Nitrous Oxide thing. . . I prefer to have my power there all the time, not just when I press a button, and I dont want it to run out either. . . only thing i want to have to fill is my gas... .but i dont think it'll hurt to squeeze during vtec. . . but wouldn't one wnat to squeeze earlier than that??? I dunno though, cuz brian spillner squeezes at 8000rpm into 7th gear. .so who knows. .:cP i'm jp dude. . .
Old Jul 29, 2003 | 04:43 PM
jdmotorsports's Avatar
Default Re: nosing in vtec (CircuitDA9)
on a stock engine its safe to start a full n2o shot above 5500 rpm and with wot.
Old Jul 29, 2003 | 04:49 PM
Havokmkr's Avatar
Default Re: nosing in vtec (jdmotorsports)
Why would you spray in VTEC? Your overlap would be at it's highest at that point. I would imagine you would squeeze just before vtec engages so that you've already combusted the nitrous and then your exhaust valve would open up to get more air out intake let more air in. You do know what vtec does right?
Edit: Oh and BTW next time I wouldn't call it NOSing, just say spraying or squeezing, because as you stated above, you don't have NOS, you have a Zex nitrous kit.
Old Jul 29, 2003 | 06:37 PM
J337_UNIT's Avatar
Default Re: nosing in vtec (Havokmkr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Havokmkr &raquo;</TD></TR><TR><TD CLASS="quote">Why would you spray in VTEC? Your overlap would be at it's highest at that point. I would imagine you would squeeze just before vtec engages so that you've already combusted the nitrous and then your exhaust valve would open up to get more air out intake let more air in. You do know what vtec does right?
wrong...if u spray too early you can damage your engine or u will cause detonation and nasty back firing....basically when you spray early its making your engine work extra hard to gain the momentum. Its best to spray when the car already has that momentum and on stock b18's i would say its best to spray around 4k+ rpm
Old Jul 29, 2003 | 10:27 PM
p1ccoloz's Avatar
Default Re: nosing in vtec (J337_UNIT)
get a zex kit and you'll be sprying only at WOT, being on the btl in vtec is fine, somewhat like turbo gs-r's...
Old Jul 30, 2003 | 02:18 PM
Havokmkr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J337_UNIT &raquo;</TD></TR><TR><TD CLASS="quote">
wrong...if u spray too early you can damage your engine or u will cause detonation and nasty back firing....basically when you spray early its making your engine work extra hard to gain the momentum. Its best to spray when the car already has that momentum and on stock b18's i would say its best to spray around 4k+ rpm</TD></TR></TABLE>
Around 4k rpm. When would that be? Hmmm, let me think, right before VTEC engages
94hatchvx
Oct 22, 2010 04:19 AM
agb13
Mar 24, 2008 09:00 AM
lukehowell88
37
Oct 25, 2007 11:48 AM
jessevtec
Sep 24, 2003 12:00 PM
2dark2bslow
Dec 10, 2002 10:50 PM
