When Going In Reverse...Where's Your Clutch Pedal?
Old Jul 29, 2003 | 09:54 AM
CPR's Avatar
CPR
Default When Going In Reverse...Where's Your Clutch Pedal?
For all my manual driving life, I've found that most of the time, the speed I'm going when in reverse make it's hard to fully release the clutch without causing a scene. Am I the only one that has a problem with this?
Old Jul 29, 2003 | 09:58 AM
RiCE On IcE 2's Avatar
Default Re: When Going In Reverse...Where's Your Clutch Pedal? (CPR)
u can realease.. it.. VERY VERYVERY slowly... i normally still have my foot on it though... cus u gotta be going in reverse for a while before u can release it slowly enuf to not cause a scene
Old Jul 29, 2003 | 10:05 AM
RTW DC2R's Avatar
Default Re: When Going In Reverse...Where's Your Clutch Pedal? (RiCE On IcE 2)
causing a scene
Old Jul 29, 2003 | 10:39 AM
B_CRUZ!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">When Going In Reverse...Where's Your Clutch Pedal? </TD></TR></TABLE>
same place... next to the brakes
no seriously I don't get your question....
Old Jul 29, 2003 | 10:48 AM
Philly_NBP_R's Avatar
Default Re: When Going In Reverse...Where's Your Clutch Pedal? (RTW DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW DC2 &raquo;</TD></TR><TR><TD CLASS="quote">causing a scene </TD></TR></TABLE>
LOL
yup - everytime...
I hits VTEC in reverse yO!
Old Jul 29, 2003 | 10:50 AM
CPR's Avatar
CPR
Default Re: When Going In Reverse...Where's Your Clutch Pedal? (b.cruz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b.cruz &raquo;</TD></TR><TR><TD CLASS="quote">
no seriously I don't get your question....</TD></TR></TABLE>
Basically, when going in reverse for a short period of time (i.e. backing out of a parking space), do you find yourself riding the clutch because you're not going fast enough to release the clutch w/o jerking the car?
Old Jul 29, 2003 | 10:51 AM
Yes - I rarely let the clutch all the way out when backing up...
Old Jul 29, 2003 | 10:53 AM
d8168055's Avatar
Default Re: When Going In Reverse...Where's Your Clutch Pedal? (Philly_NBP_R)
i reverse in neutral... i live on a slope
Old Jul 29, 2003 | 10:56 AM
Seedc2's Avatar
Default Re: When Going In Reverse...Where's Your Clutch Pedal? (d8168055)
ya majority of the time I dont release the clutch all the way because id be going to fast for the distance I need to back out from. So I guess you can call it "riding" the clutch.
Old Jul 29, 2003 | 12:05 PM
Chris N's Avatar
Default Re: When Going In Reverse...Where's Your Clutch Pedal? (kendogg)
You can do it... but VERY slowly and carefully. Usually after backing up slowly for a while I can release the clutch very smoothly.
Otherwise it is embarassing and causes a scene
Old Jul 29, 2003 | 12:07 PM
Haunt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CPR &raquo;</TD></TR><TR><TD CLASS="quote">Basically, when going in reverse for a short period of time (i.e. backing out of a parking space), do you find yourself riding the clutch because you're not going fast enough to release the clutch w/o jerking the car?</TD></TR></TABLE>
I would think most people ride the clutch when backing up...if they don't you would be jerking like a **** or going to fast...
Old Jul 29, 2003 | 12:09 PM
Dupes's Avatar
Default Re: When Going In Reverse...Where's Your Clutch Pedal? (Haunt)
I noticed that too....when I first got the car...I caused a scene at the dealership! lol
Old Jul 29, 2003 | 12:31 PM
AssPenny's Avatar
Default Re: When Going In Reverse...Where's Your Clutch Pedal? (Dupes)
Just side step that byatch!
Reverse burn outs kick the lammas ***
Old Jul 30, 2003 | 06:46 AM
gary201147's Avatar
Default Re: When Going In Reverse...Where's Your Clutch Pedal? (AssPenny)
I dont know what you actually mean by riding the clutch. When starting the car in first or in neutral i simply have to release the clutch pedal very slowly and it gets the car going without needing to feather the throttle at all, obviously when driving in the city i need to feather it a little more just so drivers behind me dont honk because i'm starting up too slow
Old Jul 30, 2003 | 12:13 PM
MK Ultra's Avatar
I briefly "ride" the clutch and then slap it in neutral. I just use the reverse gear to get going, then coast out (unless I'm in a busy parking lot where I'd prefer to keep the reverse lamps lit).
Old Jul 30, 2003 | 04:01 PM
illi Adik's Avatar
LOL, I feel that.
Old Jul 30, 2003 | 04:10 PM
Edwin's Avatar
Practise in a lot far away from people and small animals. I don't want to hear about you hurting anyone from reversing ways. LOL
Gradually ease off your clutch just as if you were clutching to go into first gear. The release should be smooth as butta.
Modified by Edwin at 5:29 AM 7/31/2003
Old Jul 30, 2003 | 04:55 PM
spd18's Avatar
Default Re: When Going In Reverse...Where's Your Clutch Pedal? (Edwin)
i push the clutch in, put it in reverse, then slowly let the clutch out as if i was starting slowly in first. after i start to move a little bit, i push the clutch back in (so im therefore in neutral) and roll back. if i need to roll farther, i will repeat the process. i never let the clutch all the way out when reversing (but i also never reverse for long distances), nor do i constantly hold the clutch halfway engaged. i just coast in neutral.
Old Jul 30, 2003 | 08:11 PM
Hairy Gorilla's Avatar
Default Re: When Going In Reverse...Where's Your Clutch Pedal? (spd18)
I always let the clutch all the way out when coming out of the driveway. I must be the masta reverse driva.
I don't know, I guess I just have the technique. I only leave it fully out for a second or 2 because you start moving quick. I then just plop it into neutral and coast, unless it is dark and I need the reverse light.
Old Jul 30, 2003 | 08:30 PM
Edwin's Avatar
Default Re: When Going In Reverse...Where's Your Clutch Pedal? (Tim Maryak)
Since we're on the topic of reverse, this has come up from time to time, but I'll ask anyways, anyone got a video of VTEC engaging in reverse?
nicks-eg6
Jan 21, 2008 01:44 PM
BLUE EH3
Jan 25, 2007 10:35 AM
ic89
Oct 17, 2006 11:59 AM
one slow coupe
19
Jan 10, 2005 08:46 PM
AspectIndustries
Jan 5, 2004 07:49 AM
