question about a garret t3 with 42 turbine and 48 exhaust
Most likely came from a saab, and yes it would be a nice turbo for that engine. I ran that same turbo on my d15 for a while and loved it, it really woke that engine up. If you use the stock internal wg that came with it you should see about 5.5psi give or take a little because those wastegates pretty much suck
i had the same turbo on my jetta i ran 8psi and it ran great, spooled very quick and held till redline, but i have a vw so my car redlines at 7k not 8 or 9k so it might run out of steam for you? after 10psi the turbo is way out of it's efficency range, it's a t3 50 trim
