electrical load detector
Old Jul 28, 2003 | 08:53 PM
Fatty_1775's Avatar
Default electrical load detector
what is the purpose of the electrical load detector? i get it at the odd times when i am at high rpms. when i restart the car, the cel goes away. also, i have a high pitched sound at the alternator at times, could that be the problem? thanks guys!
Old Jul 29, 2003 | 03:27 PM
Fatty_1775's Avatar
Default Re: electrical load detector (Autobot_Killer)
bump
Old Jul 29, 2003 | 08:59 PM
Fatty_1775's Avatar
what if it was unplugged?
Old Jul 30, 2003 | 05:10 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Autobot_Killer &raquo;</TD></TR><TR><TD CLASS="quote">what is the purpose of the electrical load detector?</TD></TR></TABLE>
It measures the electrical load from all the stuff that's turned on. When you turn on lots of stuff (lights, wipers, 700w amp...) the alternator takes more power to turn. The ELD gives the ECM advanced 'warning' so it can be prepared to use the IACV to hold the idle steady.
If it didn't work, then when you turn on all that stuff your idle speed wouldn't be real steady.
Old Jul 31, 2003 | 04:11 PM
Fatty_1775's Avatar
Default Re: electrical load detector (JimBlake)
On my ecu, there is no wire connected to where the electrical load detector part. Never had this before. Can anyone help me? Please? I can't floor the car without getting this all the time. Happens only sometime. What would make my car get a code 20? Starting to get irritating.
Modified by Autobot_Killer at 2:19 AM 8/1/2003
Old Jul 31, 2003 | 05:38 PM
Fatty_1775's Avatar
also, when i reset the ecu, i have removed the fuse and even unplugged the ground off the battery for 15 minutes, the code still shows, but no cel.
Old Aug 2, 2003 | 06:05 AM
JimBlake's Avatar
My Helm book indicates the ELD is for USA only??? With your mix of JDM engine, idunno what ECM, maybe your ECM is looking for an ELD that isn't there.
CR3X
Mar 12, 2008 07:17 PM
Fat Chick Magnet
Aug 8, 2006 06:57 AM
JDMFreak
Dec 30, 2005 11:37 AM
psyonicdeath
10
Jul 28, 2005 10:07 PM
Seedc2
Mar 6, 2004 07:48 PM
