Will I be okay running a DSM fuel pump???
Old Jul 28, 2003 | 06:05 PM
joey1320's Avatar
Default Will I be okay running a DSM fuel pump???
I asked yesterday on the EF forum if the DSM fuel pump would work on my CRX and I was told that they swap with no problem... now can I used that fuel pump instead of an aftermarket one for my turbo setup???
I have one laying around in the garage and if it's good enough for the DSM cars, will it be good enough for my CRX???
I wanna' run 11psi and the setup is almost done, all I need is the oil lines and the fuel pump.
Thanks for any info.
Old Jul 28, 2003 | 08:17 PM
SiR Kid's Avatar
New User
Default Re: Will I be okay running a DSM fuel pump??? (joey1320)
DSM fuel pumps are good to about 300hp or more as long as you don't up the pressure much. They love stock pressure environments.
The DSM one in my car was a drop in, with only the wiring needing to be done. Pump cannister was the exact same size as stock, even.
Old Jul 29, 2003 | 01:02 AM
89dxhunchback's Avatar
Default Re: Will I be okay running a DSM fuel pump??? (SiR Kid)
Glad to hear that since I'm going to be putting my factory Stealth F-pump in my civic.
Old Jul 29, 2003 | 01:11 AM
liam821's Avatar
25 Year Member
The integra GSR pump flows more then a DSM pump according to Zydne's webpage. Its one of the first mods to replace when after power in a dsm. I highly recommend NOT using a dsm pump.
If you must have a used cheap pump, try to get a supra pump, 3000GT vr4 (they are cheap), an rx7, something like that.
liam
TurboHatch95
13
Mar 1, 2005 09:20 AM
joey1320
Jul 27, 2003 10:28 PM
flat-blk-HB
Feb 5, 2003 09:43 AM
KevronsEG
Jan 7, 2003 08:01 AM
Hybrid
Feb 12, 2002 08:57 AM
