Little Black box and sensor when installing aem cai on a 5th gen
what am i supposed to do with this thing? The intake mounts in the screwhole that holds the box down. There is also a vaccum hose which runs from somewhere around my throttle body to the black box--then from the black box down into my fenderwell where my filter is that is attached to some sorta sensor.
Everything is more or less sitting in my engine bay. I was thinking about zip tying the line to other parts. Has anyone tried anything else?? AEM says you can disconnect the black box but i dont want my CEL comming on for a disconnected sensor.
thanks yall!!
thanks yall!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GruvyTune »</TD></TR><TR><TD CLASS="quote">remove the hole assembly.</TD></TR></TABLE>
amen...it is uneccessary, just make sure to cap the vacuum line on your TB>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dsludefosho »</TD></TR><TR><TD CLASS="quote">
amen...it is uneccessary, just make sure to cap the vacuum line on your TB></TD></TR></TABLE>
if you are talking about this D is right
and this a picture where you cap the thing, make sure you do this.
