what size turbo for my h22
iam looking to upgrade from my current setup which is a t3/to4b turbo
i have 2 turbos in mind which size do you think i should use: this will be going on my daily driven acura...what do you guess think is best?
T3/TO4E
COMPRESSOR SPECS:
.60 A/R HOUSING
60 TRIM WHEEL
TURBINE SPECS:
.63 A/R HOUSING
STAGE 3 WHEEL
or
T3/TO4E
COMPRESSOR SPECS:
.60 A/R HOUSING
60 TRIM WHEEL
TURBINE SPECS:
.82 A/R HOUSING
STAGE 3 WHEEL
T3/TO4E
COMPRESSOR SPECS:
.60 A/R HOUSING
60 TRIM WHEEL
TURBINE SPECS:
.63 A/R HOUSING
STAGE 3 WHEEL
or
T3/TO4E
COMPRESSOR SPECS:
.60 A/R HOUSING
60 TRIM WHEEL
TURBINE SPECS:
.82 A/R HOUSING
STAGE 3 WHEEL
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d98clturbo »</TD></TR><TR><TD CLASS="quote">T3/TO4E
COMPRESSOR SPECS:
.60 A/R HOUSING
60 TRIM WHEEL
TURBINE SPECS:
.82 A/R HOUSING
STAGE 3 WHEEL
or a 60-1 with the same specs
COMPRESSOR SPECS:
.60 A/R HOUSING
60 TRIM WHEEL
TURBINE SPECS:
.82 A/R HOUSING
STAGE 3 WHEEL
Incredible!!
I just happen to be selling a T3/60-1 with a .82 Turbine AR with stage 3 wheel and a .70 AR compressor with........the 60-1 wheel
New, just has been sitting in a bag in the box since I got it. Its a Garrett.
What luck
What luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Firedrake »</TD></TR><TR><TD CLASS="quote">It would be nice to know your horsepower goals, how much boost you're planning to run, and what kind of powerband you'd like to have......
Brian</TD></TR></TABLE>
well i hoping to get somewhere around 350whp....i only intend to run 15psi at most
i would like to be in full boost by 5000rpms...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pelican »</TD></TR><TR><TD CLASS="quote">Incredible!!
What luck
do you have any pics of this turbo? what exhaust flange does it have? (4bolt, 5bolt, V-band)
What luck
</TD></TR></TABLE>do you have any pics of this turbo? what exhaust flange does it have? (4bolt, 5bolt, V-band)
underpressure02
Feb 10, 2004 07:26 AM
