Stock 93 Si Acting up???
Old Jul 28, 2003 | 01:44 PM
JDMCivicEF9's Avatar
Default Stock 93 Si Acting up???
Its hard to explain it in words,but here it goes. The motor does this "putt" "putt" "putt" sound. It idles around 500rpms, sometimes lower and fluctuates up and down. The funny thing is when I turn on the A/C, the car just shuts off. One other thing is when I pull the spark plug wire out of cylinder #2, the car shuts off also. I never ran into something like this, and I was hoping somebody on this forum would help me out.
Old Jul 28, 2003 | 01:53 PM
hardcorepreston's Avatar
its because the a/c dews power from the little 125 hp engine.it could be that you need new spark plugs.you could always adjust your IAC.there is a lot fothings it could be.did you try searching for idle problems?
Old Jul 28, 2003 | 01:55 PM
KRiS1's Avatar
Default Re: Stock 93 Si Acting up??? (JDMCivicEF9)
time for a tune up and adjust the IAC
Old Jul 28, 2003 | 02:05 PM
Default Re: Stock 93 Si Acting up??? (POS Hatchback)
Yeah I forgot to mention that I changed spark plugs also and it still did the same thing.
Old Jul 28, 2003 | 03:09 PM
Ya@inlinePRO's Avatar
raise your idle a little bit and see if it still has the same problem.
dointhemzs
Sep 7, 2008 07:09 PM
boostede46
Apr 9, 2008 03:06 PM
99delsol
Oct 3, 2006 06:57 PM
Br1anPham
Feb 1, 2004 10:15 PM
sampol999
Jan 20, 2004 04:05 AM
