hybrid tranny
Old Jul 28, 2003 | 09:11 AM
4potnick's Avatar
Default hybrid tranny
I have been here thinking of how to put a ls tranny to good use. I was wondering about the final drive. It is a low 4.2xx but vtec tranny's usually have a 4.400. Well, what about but a type r 4.7xx final drive in a ls tranny. It would be higher than a gsr but longer than a type r. I have never heard of this being done? You can pick up ls tranny's very cheap and throw in a quaife while your at it. The main reason i wonder this is because a have a cable tranny car. As you guys know it is very difficult to find a gsr ys1 vtranny unless you want to ghet butt raped. But.... ls 92-93 trannys are only a couple hundred dollars and are large like newer hydro trannys. soooo you see why i wonder about the type r final drive. thanks
Old Jul 28, 2003 | 09:25 AM
mmuller's Avatar
Mad Scientist
Default Re: hybrid tranny (4potnick)
if you change the final drive i would advise you to change 3,4 too
Old Jul 28, 2003 | 11:03 AM
4potnick's Avatar
Default Re: hybrid tranny (mmuller)
Wouldn't 3rd,4th with this setup would still be shorter than GSR gears. Has anyone ever tried this setup?
Old Jul 28, 2003 | 11:33 AM
servion's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">if you change the final drive i would advise you to change 3,4 too</TD></TR></TABLE>
Out of curiousity, why would you advise that?
Old Jul 28, 2003 | 12:02 PM
mmuller's Avatar
Mad Scientist
Default Re: hybrid tranny (servion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by servion &raquo;</TD></TR><TR><TD CLASS="quote">
Out of curiousity, why would you advise that?</TD></TR></TABLE>
i ment 3,4 out of a itr or b16, why? cause they are shorter and help a b18b lots....
Old Jul 28, 2003 | 12:19 PM
servion's Avatar
Gotcha... I thought that you were saying to change 3 and 4 for some sort of mechanical reason. Makes sense.
HondaMan73
Oct 27, 2004 01:54 PM
4potnick
Jul 27, 2003 03:47 PM
JDMchris
Jul 26, 2002 12:39 AM
lysergican
May 6, 2002 07:58 AM
