Turbo seals / oil line press (h22)
Old Jul 28, 2003 | 09:03 AM
prelittlelude's Avatar
Default Turbo seals / oil line press (h22)
i saw this thread a while ago , and can't find it. I saw someone that posted up about their seals on their turbo going only after a couple thousand miles due to the fact that our h series has such high oil pres at high revs.,
so the question is
what size oil line do you guys use?
and do you use some time or restrictor so that the turbo seals don't see to much oil press?
and whats the max oil press a turbo needs to stay healthy?
Old Jul 28, 2003 | 09:05 AM
GZERO's Avatar
Default Re: Turbo seals / oil line press (prelittlelude)
i've heard from many sources that 35 psi is a good pressure for a turbo, if constant is better
Old Jul 28, 2003 | 09:37 AM
Default Re: Turbo seals / oil line press (GZERO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GZERO &raquo;</TD></TR><TR><TD CLASS="quote">i've heard from many sources that 35 psi is a good pressure for a turbo, if constant is better</TD></TR></TABLE>
really ? then what am i supposed to do , my oil press peaks around 100spi at high revs, should i use a very small supply line, or pus a restrictor in?
Old Jul 30, 2003 | 11:17 AM
omahaturbocivic's Avatar
I read somehwhere a while back that most garrett turbos only require 10psi although of course you can give it a lot more.
Old Jul 30, 2003 | 12:51 PM
h22 civic's Avatar
Default Re: Turbo seals / oil line press (omahaturbocivic)
100psi thats alot
Old Jul 30, 2003 | 03:38 PM
speedworks's Avatar
Default Re: Turbo seals / oil line press (h22 civic)
my car runs between 75-80 at wot and have had no problems with the seals
mister2racer
May 10, 2012 06:12 AM
SpoolnByYou
Dec 11, 2005 02:40 PM
chihuahuamanx
Jan 23, 2005 03:42 PM
prelittlelude
Jul 28, 2003 12:03 PM
Ri5e
Jun 20, 2002 10:41 AM
