Car wont start or crank, How do I trouble shoot the starter
Old Jul 28, 2003 | 06:31 AM
93si's Avatar
Default Car wont start or crank, How do I trouble shoot the starter
Anyone have any more ideas. Yes and I already check the battery and its fine.
Old Jul 28, 2003 | 06:38 AM
NiiS's Avatar
Default Re: Car wont start or crank, How do I trouble shoot the starter (93si)
Check the grounds, cheif
Old Jul 29, 2003 | 06:18 AM
93si's Avatar
done that...any other ideas
Old Jul 29, 2003 | 07:52 AM
citrusdrop's Avatar
woah my starter just kicked the bucket too...luck I am starting my H22 swap this weekend
Old Jul 30, 2003 | 11:44 AM
93si's Avatar
GSR swap with P23. Cars been running fine until now. By the way my car is a 93 si.
Old Jul 30, 2003 | 11:55 AM
NiiS's Avatar
Default Re: (93si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93si &raquo;</TD></TR><TR><TD CLASS="quote">GSR swap with P23. </TD></TR></TABLE>
I think you mean P28?
Old Jul 30, 2003 | 11:56 AM
NiiS's Avatar
Default Re: (sinister)
How did you check the battery? Have you tried to jump it?
Old Aug 1, 2003 | 06:55 AM
93si's Avatar
yeah... tried to jump started
Old Aug 1, 2003 | 09:23 AM
degooser's Avatar
fuses??? if you haven't done so already...
Old Aug 1, 2003 | 09:57 AM
Damon's Avatar
lightly tap the starter with a hammer, or anything with a lil weight. If it starts, the starter is bad.
Old Aug 1, 2003 | 10:22 AM
Noe Kozz's Avatar
Default Re: (Damon)
or plug a wire from your starter to your battery. Make contact with the positive side and if it turns over........it's probably your starter.
Old Aug 1, 2003 | 11:23 AM
fakemike's Avatar
Default Re: (Noe Kozz)
My starter would always stick and I would have to bang on it with my Mag-Lite. Atfer about two years of this the starter finally went bad. If it still won't turn over your starter is pretty easy to remove and take to a local auto parts store to be tested for free.
Old Aug 3, 2003 | 08:55 PM
93si's Avatar
replcaed the starter this weekend. Car didnt start at first. I had to jump the starter from the battery and ground it to the battery as well. Car now starts like a champ, but I am afraid that something else mind be the problem.
lilsol89
Jan 5, 2009 03:57 PM
pgpunkguy
Jan 22, 2008 11:29 AM
go2sleep
May 6, 2007 08:42 PM
tchen415
Sep 12, 2006 04:55 PM
porkchop14
Sep 28, 2004 09:10 AM
