Benefits of pillow ball mounts
Old Aug 5, 2001 | 10:21 PM
girlRacer's Avatar
Default Benefits of pillow ball mounts
Can someone explain the benefits of pillow ball mounts? Thanks.
Old Aug 5, 2001 | 11:33 PM
Scorpaznatica's Avatar
New User
Default Re: Benefits of pillow ball mounts (girlRacer)
Pillowball mounts use solid spherical bearings rather than soft rubber bushings. In short, it reduces the dampening effect of the OE bushings and replacing it with a more direct feel of the road.
If you're in a hatchback (i.e. DC2) where you can see the rear damper from the back seat, take a look at the bushings when the car is being driven. You'll see that damper rod move everywhere, because the bushings are compressed. Well a spherical bearing will eliminate those movements...essentially, allowing better response when you navigate your car through turns, etc.
It's useless until you hit the track. And I dont mean drag racing.
Old Aug 6, 2001 | 01:18 AM
ITR.00-1282
Guest
Posts: n/a
Basically, the main benefit of pillow ball mounts is improved handling at the cost of ride quality. Your assbone will hurt when you're going over speedbumps and potholes.
Old Aug 6, 2001 | 08:05 AM
girlRacer's Avatar
Default Re: Benefits of pillow ball mounts (ITR.00-1282)
Thanks for the info. I understand it now.
darkintegra
Suspension & Brakes
Sep 12, 2008 07:36 PM
Airbag Club
11
Nov 22, 2006 12:09 PM
knowledge112
Aug 10, 2004 02:15 PM
purplevtec
Jun 25, 2004 03:54 PM
